Kinetic Energy, work and force Sand conveyor problem
In summary, the power supplied to the sand on the belt is 240 watts, but the KE rate of change is different because dissipation of energy occurs.
magiclink
23
In the attachment!
P=F*v=F*d/t=Work/t
KE=(mv^2)/2
W=f*s
For the first question, I Found it rather difficult to figure out WHAT exactly accelerated the sand. I would simply say the force of the engine? But at the same time in order for the sand falling to gain horizontal velocity it would need friction to keep it in place on the conveyor belt. But in what direction does the force of the friction act exactly? I feel like it'll just fall and plonk itself there. The force just holding it unto the conveyor belt!
For the second question I'm more befuddled. To calculate this force I thought that perhaps I could use F= rate of change of momentum to solve it. So if initial velocity is 0 then the change will be 60*2=120. But then I find that perhaps one could use KE formula as well? I thought that if all the force goes into changing the velocity of the sand then i could backpedal (work=KE)/distance, but that yields 60N! half the amount! :S
Calculating the power seems simple enough using the Power formula. But i'd either end up with 240 or 120, using the velocity 2 m/s and the 'KE-derived' force or the 'momentum' derived force.
It later also asks why the rate of change of KE isn't the same as the power? I peeked at the answer after thinking long and hard and they wrote that it's due to loss of energy due to friction, gain in internal energy of conveyer belt. What confuses me with this is that I thought that the KE formula doesn't take this loss into account, or does it? I thought the KE formula would calculate the work change assuming that ALL the energy goes to change the object's KE, nothing else!
To round off. I'm having trouble resolving the ideas of KE and F*d=W. I thought that the KE of the sand rate of change would be equal to F*2/time and also to the Power. Can anybody explain this to me in a concise manner? Thankyou so much. This site's a lifesaver.
magiclink said:
In the attachment!
P=F*v=F*d/t=Work/t
KE=(mv^2)/2
W=f*s
Without the friction, what would the sand do? That should tell you the direction of the frictional force.
Don't just write down numbers, use symbols. That way you can see what is going on in your equations. Also, you must always indicate units; a number with no unit is utterly meaningless. If you do those things, you will see something missing in your numbers.
Reviewing my reply, perhaps it was not very clear. Start with the complete equation for force:
[tex]\vec F = \frac{d\vec p}{dt}[/tex]
and look at the system (belt plus sand) as a whole.
Hi! You're right. I ought to write out my equations a little more properly. I've gone over the problem and think I'm getting to grips with understanding it. There's just one question that really still bugs me.
If kinetic energy is the work done in giving an object a certain velocity, can I calculate the work done per second on the sand on the conveyor belt using the KE formula?
So. mass* velocity^2/2= 60 kg (mass of sand) * 2 m/s *1/2 = 120 watts
Alternatively, I would think you could also figure out the work done using the Power=force*velocity.
Force being dp/dt= 60 kg *(2-0) m/s (change in velocity) / 1 second
= 120 N.
Then plugging that into P=F*v, Power= 120 N * 2 m/s= 240 W!
My question then is why isn't the rate of change of kinetic energy equal to the power supplied? I understand that friction and gain in internal energy, etc. would cause dissipation of energy and therefore more power is required. But I thought both equations do not take these losses into account? Why is the KE rate of change any different from the power supplied?
That's my great hangup! I'd be really thankful if you could enlighten me on that front? :) Thankyou!
I always thought of KE as the work done in giving the object energy. So why can't one calculate the power using the kinetic energy formula/time, if gain in KE is nothing but work?
you are correct to use force = rate of change of momentum to find the force.
To calculate KE you need average force x velocity
You are also correct to identify that the discrepancy in energy is due to work done against friction (heat)
Correction: power = average force x velocity (KE per second)
It might also help to think about the problem as a 'continuous' inelastic collision. You (should) know that kinetic energy is not conserved over inelastic collisions...
Again, look at the complete equation for force:
Don't forget that, for the belt plus sand system, mass is not constant. That is,
[tex]\vec F = \frac{d\vec p}{dt} = \vec v \frac{dm}{dt} + m \frac{d\vec v}{dt}[/tex]
Look at the entire system, not just the sand falling onto the belt.
Related to Kinetic Energy, work and force Sand conveyor problem
1. What is Kinetic Energy?
Kinetic Energy is the energy an object possesses due to its motion. It is defined as the work needed to accelerate a body from rest to its current velocity.
2. How is Kinetic Energy calculated?
Kinetic Energy (KE) is calculated using the formula KE = 1/2 * mass * velocity^2. This means that the kinetic energy of an object is directly proportional to its mass and the square of its velocity.
3. What is Work in relation to Kinetic Energy?
Work is the measure of energy transfer that occurs when a force is applied to an object and causes displacement in the direction of the force. In the context of Kinetic Energy, work is what is done to accelerate an object from rest to its current velocity.
4. How is Work calculated in the context of the Sand conveyor problem?
In the Sand conveyor problem, work is calculated using the formula W = F * d, where W is work, F is the applied force, and d is the displacement of the sand on the conveyor. This formula assumes that the force is constant and in the same direction as the displacement.
5. What is the relationship between Force and Kinetic Energy?
Force and Kinetic Energy are directly related. The greater the force applied to an object, the greater its acceleration and therefore, the greater its Kinetic Energy. This is because the work done by the force results in an increase in the object's Kinetic Energy.
