Kinetic equilibrum and chemical equilibrium
In summary: At that point, the equilibrium is effectively reached, regardless of whether or not the particle species is still in chemical equilibrium with the rest of the universe. Basically, yes. What causes the "freezing out" is the rates of all relevant reactions that interchange the particle species under consideration with other species, becoming low enough to be negligible. At that point, the equilibrium is effectively reached, regardless of whether or not the particle species is still in chemical equilibrium with the rest of the universe.
karlzr
131
All particle species are in equilibrium at early times of the universe. But I didn't find any book that makes the difference of kinetic and chemical equilibrium clear. I have some of my own opinions and I hope to get your comments:
(1) kinetic equilibrium means the distribution function obeys the Bose-Einstein or Fermi-Dirac distribution with a well-defined temperature. This concerns only one specific particle species. Then kinetic equilibrium can be reached as long as it scatters rapidly enough with any particle while keeping its particle number unchanged: ##a + b \to a + b##.
(2) While chemical equilibrium involves at least two particle species that are connected by processes that change the particle number: ##a + b \to c + d## or ##a \to b + c##.
So whether some particle species such as ##t## quark is in equilibrium depends only on the thermally averaged cross section related to that specific kind of equilibrium. Thermodynamic equilibrium means both kinds of equilibrium are satisfied. Same temperature applies only to thermodynamic equilibrium, right?
So when we say some particle freezes out at some point, we really mean it is out of chemical equilibrium with the rest of the universe but it may still be in kinetic equilibrium with itself and thus maintain a different temperature.
Thanks,
Space news on Phys.org
I think you are confusing particles with atoms.
Atoms must exist in order for any kind of chemistry to happen.
In the very early Universe there were no atoms, and only after it had cooled considerably, atoms appeared.
However nearly all atoms at that time were hydrogen or helium, and those do not chemically react.
Much more time then elapsed before stars formed and other elements were produced, and more time still until these heavier elements became dispersed into the intersellar medium.
Only at that stage could any chemical processes occur.
Not necessarily. The term "chemistry" can refer to nuclear reactions that change particle numbers. (More often you see related usage such as the term "chemical potential" to describe terms appearing in the thermodynamic equations for systems containing multiple particle species.) Such reactions certainly exist and are relevant under the conditions the OP is describing, so even if you don't like the term "chemistry" to describe what the OP is describing, what he's describing certainly occurs.
PeterDonis said:
Not necessarily. The term "chemistry" can refer to nuclear reactions that change particle numbers. Such reactions certainly exist, so even if you don't like the term "chemistry" to describe what the OP is describing, what he's describing certainly occurs.
Thanks.
I did not know of the term 'chemistry' being used in that context.
(but now i do - :smile:)
FAQ: Kinetic equilibrum and chemical equilibrium
1. What is the difference between kinetic equilibrium and chemical equilibrium?
Kinetic equilibrium refers to the balance between the forward and reverse reactions of a chemical reaction, where the rate of the forward and reverse reactions are equal. Chemical equilibrium, on the other hand, refers to the balance between the concentrations of reactants and products in a chemical reaction, where the concentrations remain constant over time.
2. How is kinetic equilibrium achieved?
Kinetic equilibrium is achieved when the rate of the forward reaction is equal to the rate of the reverse reaction. This can be achieved by changing the temperature, pressure, or concentration of the reactants.
3. What factors affect chemical equilibrium?
Factors that affect chemical equilibrium include temperature, pressure, and concentration of reactants and products. Changes in these factors can shift the equilibrium towards the reactants or products, depending on the direction of the change.
4. Can equilibrium be disturbed?
Yes, equilibrium can be disturbed by changes in temperature, pressure, or concentration. When these factors are changed, the equilibrium will shift in order to re-establish balance.
5. How can we calculate the equilibrium constant for a reaction?
The equilibrium constant (Kc) for a reaction can be calculated by dividing the concentration of the products raised to their respective coefficients by the concentration of the reactants raised to their respective coefficients. This can be expressed as Kc = [Products]/[Reactants].
