wvguy8258
- 50
Hi,
So I've read that kinetic friction does not depend upon velocity, but that air resistance does depend upon velocity. I hope those two statements are correct from the get go.
I can see why the force of kinetic friction does not depend upon speed using a simple thought experiment. You have two surfaces that are smooth except for little dome-shaped studs on each. Let's say you only hit one stud at a time. At any instant you are only overcoming the resistance from one stud hitting another. This should not depend upon how quickly studs collide in succession as you only hit one at any instant. So, it makes sense to me that the force remains roughly the same.
Now, with air resistance you have air molecules sliding across the surface and also colliding with it in the direction of movement (we are pulling one surface through air and the surface has depth and this perpendicular edge will slam into air). At anyone intance in time, you would seem to have the same situation as in the previous paragraph and so air resistance would not change with the velocity of the surface moving through the air. However, I believe it does change.
Any intuitive explanation for why? I'm thinking it has something to do with air being able to move along with the surface and also air piling up against the front ledge where impacts are occurring.
