Kinetic friction find greatest acceleration
To determine the direction of the applied force needed to move a crate on a rough horizontal floor with a coefficient of kinetic friction of 0.40, the force should be applied at an angle that minimizes the required force. The normal force is calculated using the formula Fn = m*a*cos(theta), and the kinetic frictional force is derived from Fk = (uk)*|Fn|. The discussion emphasizes using Newton's second law to set up equations for the vertical and horizontal components of the applied force. The goal is to find the optimal angle for the force application to achieve the greatest acceleration with the least effort. Understanding these principles is crucial for solving the problem effectively.
Sneaky07
1. A crate resting on a rough horizontal floor is to be moved horizontally. The coefficient of kinetic friction is 0.40. To start the crate moving with the least possible applied force, in what direction should the force be applied?
a. Horizontal
b. 24 degrees below horizontal
c. 22 degrees above the horizontal
d. 24 degrees above the horizontal
e. 66 degrees below the horizontal
Formulas I used.
2. (Normal force) Fn = m*a
(Kinetic frictional force) Fk = (uk)*|Fn| (uk being coefficient of kinetic friction)
Work I did.
3. Figured out the normal force which was m*a*cos(theta). After I multiplied it by the (uk) and got kinetic frictional force but don't know where to go from there...
Thanks in advance!
Welcome to PF!
Thanks in advance!
Hi Sneaky07! Welcome to PF! :smile:
(have a theta: θ and a mu: µ :wink:)
However did you get m*a*cos(theta)? :confused:
Hint: this is a straightforward Newton's second law problem …
call the force "F", then take vertical components and horizontal components (separately), to get two equations for F. :smile:
  • · Replies 17 ·
  • · Replies 16 ·
