Kinetic friction on an incline.
In summary: I thought the force normal was no longer perpendicular if I took the cos(13) of it.I thought the cos made it parallel. That is why I was adding them.
algar32
89
A box is sliding down an incline tilted at a 13.0° angle above horizontal. The box is initially sliding down the incline at a speed of 1.40 m/s. The coefficient of kinetic friction between the box and the incline is 0.370. How far does the box slide down the incline before coming to rest?
mk= Fnormal*ms
1.4 m/s in x direction= m*cos(13)
m=1.4368
m*ms= 1.4368*.37=.51363= mk
1.4m/s-.51368mk= .868m
Not sure what I am doing wrong. Thanks.
m=1.4368
I don't quite understand what you've done or even what your equations mean.
Try this: What forces act on the box? Figure out the resulting acceleration of the box as it slides down the incline.
I found mass and then found the amount of kinetic friction. Then I subtracted that from the 1.4 m/s. Ill be honest. I know I am doing it wrong and I have no Idea what I am supposed to do. I guess I will keep googling it until I find something. Thanks.
The force that act on the box are gravity, fnorm, and kinetic friction.
Good. Now express the net force parallel to the incline. Then use Newton's 2nd law to find the acceleration.
kinetic friction = not sure. I don't have a mass.
fnormal = not sure don't have mass.
fgravity = not sure don't have a mass
Unless my mass from the first part was correct?
You won't need a numerical value for the mass. Just call the mass 'm' and continue. Write expressions for these forces symbolically, not numerically.
Nope.
Ok thanks.
kinetic= -.370*m
fnorm= cos(13)*9.8
kinetic +fnorm= 9.17
9.17m=m*a
9.17=a
Is this right^^?
Then how do I find the distance?
Thanks so much.
algar32 said:
Ok thanks.
kinetic= -.370*m
No. The force of kinetic friction equals μFnorm.
fnorm= cos(13)*9.8
Not exactly. (But you're close.) First, what does the weight equal? Then how does Fnorm relate to the weight?
Once you find the correction acceleration, you'll use kinematics to find the distance.
algar32 said:
kinetic= -.370*m
This is incorrect. Force of kinetic friction = μF[itex]_{Normal}[/itex]
algar32 said:
fnorm= cos(13)*9.8
Good.
9.17m=m*a
9.17=a
Is this right^^?
Thanks so much.
Kinetic friction and the normal force are not on the same plane, you can't add them together. Think about it. What is the only force that is causing the block to deccelerate? After you find the acceleration just use v[itex]^{2}[/itex]=v[itex]^{2}_{f}[/itex]+2ad and solve for distance.
kinetic= -.370* cos(13)*9.8*m
fnorm= cos(13)*9.8*m
kinetic +fnorm= 6.0
6.0m=m*a
6.0 = a
vf^2= vi^2 + 2ad
0= 1.4^2+ 2*(6)*d
d= -.1633
Still not sure what I did wrong :(
algar32 said:
kinetic +fnorm= 6.0
Again, don't add these two together. Think of it this way. What is your net force and what does friction have to do with it?
Well net force is my overall force right? So I figure you just add them ( I added the negative sign in front of the friction, so It is really like subtracting).
Good. That's one of the forces acting parallel to the incline.
OK. But realize that this force acts perpendicular (normal) to the incline surface.
kinetic +fnorm= 6.0
Why are you adding those forces? (They don't act in the same direction, for one.) And why are you setting it equal to 6.0?
What you need is the net force parallel to the incline. (What about gravity?)
I thought the force normal was no longer perpendicular if I took the cos(13) of it. I thought the cos made it parallel. That is why I was adding them.
Sorry I was unclear. i wasn't setting it equal to 6.0. That is what it equaled when added.
ughh so confused! :(
Thanks for your help thus far but, I am clearly not competent enough to do this problem. Can someone just show me the equations I need and I will try to figure it out.
No. Multiplying the weight (mg) by cosθ gives you the normal force, which is perpendicular to the surface. But the friction force is parallel. To get the friction force, multiply the normal force by μ.
But the friction force is just one of the forces. The other force is the component of the weight parallel to the surface. Hint: If multiplying the weight by cosθ gives you the perpendicular component of the weight (which is equal to the normal force), what would you need to multiply the weight by to get the parallel component?
fgrav (weight)= m*9.8*sin(13)
acceleration= -1.329
0= 1.4^2+2(-1.329)d
d=.737
WE DID IT. I LOVE YOU FOREVER!
Thanks.
Nice work.
FAQ: Kinetic friction on an incline.
1. What is kinetic friction on an incline?
Kinetic friction on an incline is the force that resists the motion of an object sliding down an inclined surface. It is caused by the interactions between the surfaces of the object and the incline.
2. How is kinetic friction on an incline different from regular kinetic friction?
Kinetic friction on an incline differs from regular kinetic friction because it acts in the direction parallel to the incline, while regular kinetic friction acts in the opposite direction of motion.
3. What factors affect the magnitude of kinetic friction on an incline?
The magnitude of kinetic friction on an incline is affected by the coefficient of kinetic friction between the two surfaces, the weight of the object, and the angle of the incline.
4. How is the magnitude of kinetic friction on an incline calculated?
The magnitude of kinetic friction on an incline can be calculated using the formula Fk = μk * Fn, where Fk is the force of kinetic friction, μk is the coefficient of kinetic friction, and Fn is the normal force acting on the object.
5. How does the angle of the incline affect kinetic friction?
The angle of the incline affects kinetic friction by changing the normal force acting on the object. As the angle increases, the normal force decreases, resulting in a decrease in the magnitude of kinetic friction.
