Kinetic Friction with an upward shove
In summary, the conversation discusses a problem involving a block sliding up an inclined plane with a coefficient of kinetic friction of 0.17 and an angle of 55°. The question is asking for the block's acceleration (magnitude and direction) when given an upward shove. The person has also solved for the block's acceleration when sliding down and got an answer of 7.079 m/s^2. They have tried two different methods to solve the problem but both were incorrect.
lauriecherie
44
In the figure below, the coefficient of kinetic friction between the block and inclined plane is 0.17 and angle θ = 55°. What is the block's acceleration (magnitude and direction) assuming the following conditions? (b) It has been given an upward shove and is still sliding up the slope.
I also figured out that the accelertaion (magnitude and direction) when it is sliding down. That answer is 7.079 m/s^2
I've tried 8.036 & 7.079 m/s^2. Both were incorrect :(
Hi lauriecherie,
What did you do to get those answers?
I would first clarify the given information. The coefficient of kinetic friction between the block and inclined plane is 0.17 and the angle of the inclined plane is 55°. The block has been given an upward shove and is still sliding up the slope. The question asks for the block's acceleration in terms of magnitude and direction.
To solve this problem, we can use the equation for Newton's second law of motion, F=ma, where F is the net force acting on the block, m is the mass of the block, and a is the acceleration of the block.
First, we need to determine the net force acting on the block. Since the block is sliding up the slope, the net force must be directed up the slope. The only forces acting on the block are the force of gravity (mg) and the force of kinetic friction (μkN), where N is the normal force exerted by the inclined plane on the block.
We can find the normal force by breaking it into its components. The normal force is perpendicular to the inclined plane, so its vertical component is equal in magnitude and opposite in direction to the force of gravity (mgcosθ). The horizontal component is equal to the force of gravity acting down the slope (mgsinθ).
Next, we can plug these values into the equation for the net force, F=ma. Since the block is still sliding up the slope, the acceleration must be directed up the slope as well. Thus, we can set up the following equation:
ma = μkN - mgsinθ
Substituting in the values for N and sinθ, we get:
ma = μk(mgcosθ) - mg(sinθ)
Solving for a, we get:
a = (μkcosθ - sinθ)g
Plugging in the given values of μk = 0.17 and θ = 55°, we get:
a = (0.17cos55° - sin55°)(9.8 m/s^2) = 1.95 m/s^2
Therefore, the block's acceleration in terms of magnitude and direction when it is sliding up the slope is 1.95 m/s^2 directed up the slope. This is significantly lower than the acceleration when the block is sliding down the slope, which is 7.079 m/s^2 directed down the slope. This is due to the opposing
FAQ: Kinetic Friction with an upward shove
What is kinetic friction with an upward shove?
Kinetic friction with an upward shove refers to the resistance force that occurs when an object is in motion and is pushed or pulled in an upward direction. This force is caused by the interaction between the object and the surface it is moving on.
How is kinetic friction with an upward shove different from regular kinetic friction?
Kinetic friction with an upward shove is different from regular kinetic friction because it occurs when there is an external force pushing or pulling the object in an upward direction. Regular kinetic friction only occurs when the object is moving in a horizontal direction.
What factors affect the amount of kinetic friction with an upward shove?
The amount of kinetic friction with an upward shove is affected by the weight of the object, the type of surface it is moving on, and the force of the upward shove. It is also affected by the coefficient of kinetic friction, which is a measure of the roughness or smoothness of the surfaces in contact.
How can kinetic friction with an upward shove be reduced?
Kinetic friction with an upward shove can be reduced by using lubricants, such as oil or grease, to reduce the friction between the object and the surface. Another way to reduce this type of friction is by decreasing the weight of the object or by using a smoother surface for the object to move on.
What is the significance of understanding kinetic friction with an upward shove?
Understanding kinetic friction with an upward shove is important in many scientific fields, such as physics and engineering. It allows us to predict and control the motion of objects in various scenarios, and to design more efficient and effective systems and machines. It also plays a crucial role in everyday activities, such as walking, driving, and sports, where friction with an upward shove can affect our movements and performance.
