physconomic
- 15
- 1
- Homework Statement
- So if you have a gas that is a combination of H##_2## and HD (hydrogen-hydrogen and hydrogen-deuterium) in the proportion of 7000:1, and it effuses through a hole at constant temp into a vacuum whereby the proportion changes to 700:1, what factor would the pressure have changed?
- Relevant Equations
- Daltons law
##p = n_1 K_B T##
Effusion rate: ##\frac{1}{4} n \bar{v}##
So I know Dalton's law as stated above which I think is applicable in this question. Then I know the effusion rate is ##\frac{1}{4} n \bar{v}##, and from this we can make a differential for the time evolution of the number density of the gas in the container which is:
##\frac{dn}{dt} = \frac{A}{\phi} = \frac{A}{4}n \bar{v}##
Therefore: ##\frac{dn}{n} = \frac{A\bar{v}}{4}dt##
As ##n = \frac{n_0}{v}##, then the solutions must be:
##n = n_0 e^{-\frac{At}{4}n}## for each of H##_2## and HD
I'm not sure if this is the right way to go about this, or how to link this to get a change in the factor of the pressure in the vessel?
Thank you
Thank you
