sponsoredwalk
- 533
- 5
Hey I'm studying the Kinetic Theory of gases and although it's in a chemistry
book it employs physics concepts ergo I have come here to ask you nice people![Big Grin :biggrin: :biggrin:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The 5th point is where I have a problem, the rest is just information for you.
I am assuming a particle is in a cube (ideal situations here) & it traverses a
distance l with a momentum p=mv.
1. As it travels forward it will hit the cube wall and the resultant change in
momentum will be;
[tex]change \ in \ momentum \ = \ (mv) \ - \ (-mv) \ = \ 2mv[/tex]
2. The number of collisions per second will be;
[tex]No.\ of \ collisions \ per \ second \ = \ \frac{velocity}{distance} \ = \ \frac{v}{l}[/tex]
3. The Change in momentum per second will be;
[tex]Change \ in \ momentum \ per \ second = 2mv \frac{v}{l} \ = \ \frac{2mv^2}{l}[/tex]
4. I've assumed one particle in one direction. Assuming n particles with
a total change in momentum per second of;
[tex]total \ change \ in \ momentum \ per \ second \ = \ \frac{2m}{l} \ \displaystyle\sum_{i=1}^n v_i^2 [/tex]
5. Here is where I have the problem. The text says to do this next;
Define the root square mean velocity, [tex]\overline{v} [/tex] such that;
[tex]\overline{v}^2 \ = \ \left( \ \frac{1}{n} \ \sum_{i=1}^n v_i^2 \right) [/tex]
What does this mean? Is this some mathematical concept from probabilities? I haven't done probabilities in math in like 5 years & even then that was in school . Where did the [(2m)/l] fraction go?
Using this concept the book goes on to show that;
[tex] The \ total \ change \ in \ momentum \ = \ [2mn \overline{v}^2 ] / l [/tex]
(that is a fraction with l in the denominator, all the rest in the numerator [latex issues] )
I can't understand this (or any of the further concepts on pressure etc...) without getting this concept.
momentum will be;
