Kinetic to Elastic Potential Energy
In summary, the conversation discusses a scenario involving a moving car with 40,000 J of kinetic energy at a speed of 7.0 m/s and a spring-loaded bumper that compresses 0.30 m when the car hits a wall and stops. From this information, it can be learned that the bumper's spring has a constant of 8.9x10^5 N/m. Assumptions made include the conservation of energy and the absence of compressions in other parts of the system during the impact.
logan3
83
A moving car has 40,000 J of kinetic energy while moving at a speed of 7.0 m/s. A spring-loaded automobile bumper compresses 0.30 m when the car hits a wall and stops. What can you learn about the bumper’s spring using this information? Answer quantitatively and list the assumptions that you made.
[itex]KE = 40,000 J[/itex]
[itex]v_i = 7.0 m/s[/itex]
[itex]v_f = 0 m/s[/itex]
[itex]\vec s = 0.30 m[/itex]
[itex]KE = Elastic PE = \frac {1}{2} k {\vec s}^2 \Rightarrow k = \frac {2KE}{{\vec s}^2}[/itex]
[itex]k = \frac {2(40,000 J)}{(0.30 m)^2} = 888888.88 N/m \sim 8.9x10^5 N/m[/itex]
I learned that the bumper's spring has a constant of 8.9x10^5 N/m. I assumed that energy wasn't lost from the point when the car had 40,000 J of KE to when it impacted the wall, i.e. the energy was perfectly conserved.
Thank-you
Looks ok. Not sure it is necessary to require that work is perfectly conserved, nor is it the time up to the impact that's of interest. Even if the spring failed to re-expand when released, the answer would be the same. Might be more relevant to mention that you assume there are no compressions anywhere else in the system (car or wall) during the impact.
Thank-you haruspex.
Related to Kinetic to Elastic Potential Energy
1. What is the difference between kinetic and elastic potential energy?
Kinetic energy is the energy an object possesses due to its motion, while elastic potential energy is the energy stored in an object when it is stretched or compressed.
2. How is kinetic energy converted into elastic potential energy?
When an object with kinetic energy comes into contact with a spring, the spring exerts a force that is proportional to the amount of compression or stretching. This force converts the kinetic energy of the object into elastic potential energy in the spring.
3. How is elastic potential energy released?
Elastic potential energy is released when the force that is keeping an object in a stretched or compressed state is removed. This can happen when the object is released or when the force is removed manually.
4. Can kinetic energy be converted back into elastic potential energy?
Yes, kinetic energy can be converted back into elastic potential energy. This can happen when the object that was stretched or compressed is released and the elastic potential energy stored in the spring is converted back into kinetic energy as the object starts to move.
5. What are some real-life examples of kinetic to elastic potential energy conversion?
Some examples include a person jumping on a trampoline, a ball bouncing on a surface, and a spring-powered toy car. In all of these cases, the kinetic energy of the object is converted into elastic potential energy in the spring or surface, which is then released as the object bounces back up.
