Kinetics: Initial rates method
In summary: As for postulating a mechanism based on the rate law, it can be challenging as it requires a deep understanding of the reaction and its kinetics. It is not always possible to determine the exact reaction mechanism based on the rate law alone. In summary, the method of initial rates involves measuring the rate of reaction at the beginning, and the calculation provided is for the average rate. The reaction mechanism for the iodine clock reaction involves redox reactions and can be difficult to determine based on the rate law alone.
linyen416
In the iodine clock reaction involving persulfate and potassium iodide: why is the experimental method of determining rate law called 'method of initial rates' when acutally the 'average' rate is measured? How does 'intial' come into play?
From what I've read it is because you're 'supposed' to be measuring the initial rate, but I thought the intitial rates must be found by plotting a concentration vs. time graph and using the gradient of the curve at t =0?
Also, is this calculation correct:
rate = (volume of thiosulfate added* concentration of thiosulfate added)
(2*total volume of reaction mixture*time for blue colour)
Or is this the 'initial' rate?
I think it is the average rate.
Regarding rection mechanism, I have found that the reaction mechanism of this iodine clock is only referring to the molecular steps in the first equation: the reaction between KI and S2O8. IS that right and how do I go about postulating a mechanism for this reaction based on the rate law I know: 1st order wrt both KI and persulfate?
Or is the reaction mechanism harder to determine?
The method of initial rates is referring to measuring the rate of reaction at the very start of the reaction. This is usually done by plotting the concentration of the reactants and products versus time and then taking the gradient of the curve at t = 0. The calculation you provided is the average rate, which is obtained by measuring the amount of product formed over a period of time and dividing it by the total reaction volume and time taken for the reaction. In terms of the reaction mechanism, the reaction between KI and S2O8 is a redox reaction that involves the oxidation of iodide ions to iodine molecules by persulfate ions. This can be further broken down into more specific steps, such as the formation of an intermediate complex and the transfer of electrons. However, this is not necessarily related to the rate law, which is determined primarily by experiments.
The experimental method of determining rate law using initial rates is called the "method of initial rates" because it involves measuring the initial rate of reaction at various initial concentrations of reactants. This allows us to determine the order of reaction with respect to each reactant, as well as the overall rate law. The term "initial" refers to the beginning of the reaction, when the concentrations of reactants are at their highest and the rate is at its fastest.
The calculation you have provided appears to be for the average rate of the reaction, not the initial rate. The initial rate is typically measured by taking the slope of the tangent to the curve at t=0, as you mentioned, or by plotting a concentration vs. time graph and determining the initial rate from the initial concentration change. This is because the initial rate is often the most accurate representation of the reaction rate, as it is not affected by any secondary reactions or product formation that may occur later in the reaction.
The reaction mechanism for the iodine clock reaction may involve multiple steps, but the reaction mechanism often refers to the overall process of the reaction. In this case, the reaction mechanism may involve the initial reaction between KI and S2O8, as well as any subsequent reactions that may occur to form the final products. Determining the reaction mechanism from the rate law can be challenging and may require further experimentation or mathematical modeling.
Related to Kinetics: Initial rates method
What is the initial rates method?
The initial rates method is a technique used to determine the initial rate of a chemical reaction. It involves measuring the change in concentration of reactants or products over a short period of time at the beginning of the reaction.
Why is the initial rates method important?
The initial rates method allows scientists to determine the rate of a reaction without having to wait for the reaction to reach completion. This is especially useful for reactions that may take a long time to reach equilibrium.
How is the initial rate of a reaction calculated using this method?
The initial rate of a reaction can be calculated by dividing the change in concentration of a reactant or product by the corresponding change in time. This can be determined by plotting a graph of concentration versus time and finding the slope of the initial straight line.
What are the advantages of using the initial rates method?
The initial rates method allows for a quick determination of the reaction rate and can be used to compare reaction rates under different conditions. It also does not require the reaction to reach equilibrium, making it applicable to a wider range of reactions.
Are there any limitations to the initial rates method?
One limitation of the initial rates method is that it can only be used for reactions that have a linear relationship between concentration and time at the beginning of the reaction. It also requires precise and accurate measurements of concentration and time, which can be challenging for some reactions.
