Kinetics Problem: Finding average normal force
In summary, when a 2kg ball is thrown at a suspended 20kg block with a velocity of 4m/s, and the time of impact is 0.005s, the average normal force exerted on the block during this time can be determined using the equations mava+mbvb=mava'+mbvb', e=vb'-va'/va-vb, and mv1+Ft=mv2. After calculating the velocities of the ball and block using these equations, the change in momentum of the block can be divided by the time during the change to find the average normal force exerted, which in this case is 2618 N.
woody89
I'd just like to say thank-you in advance for any and all answers. It is greatly appreciated. :smile:
The 2kg ball is thrown at the suspened 20kg block with a velocity of 4m/s. If the time of impact between the ball and the block is 0.005s, determine the average normal force exerted on the block during this time. Take e=0.8.
e=vb'-va'/va-vb
mv1+Ft=mv2
First I designated a to denote the ball and b to denote the block
Using mava+mbvb=mava'+mbvb'
I know that because the block is at rest and therefore vb=0m/s
Subbing in the values given in the problem statement I was able to create an equation for vb' and va'
(2)(4)+(0)=(2)va' + (20)vb'
once simplified I had 4=va'+10vb' --->eq1
Then using e=vb'-va' /va-vb and the values given in the problem I was able to get another equation for vb' and va'
0.8= vb'-va' /2
1.6=vb' -va' ---->eq2
eq1+eq2 gave me vb'=0.509m/s which I then used to find va'=2.12m/s
Then using mv1+Ft=mv2 and va'=2.12m/s as v2 I calculated for F
F=(2)(2.12)-(4)(2)/0.005 = -756.36 N
This value of F seemed very large to me given that the ball is traveling as a speed of only 4m/s.
Because my assignments are done online I know, as I tried pluging in this value, that that is not the correct answer:frown:. My problem is that I have no idea where it is that I went wrong. Any direction on this would be greatly appreciated. :smile:
"0.8= vb'-va' /2" is wrong. (vb'-va')/4 = 0.8.
ehild
woody89 said:
0.8= vb'-va' /2
Recheck your work. The momentum before the collision is
Pbefore= 2*4 = 8.0 kg m/s
If your calculation is correct, the momentum after is
Pafter=2*2.12 + 20*0.509 = 14.4 kg m/s
and your numbers imply that momentum is not conserved.
Without seeing your exact calculation, it is hard to figure out where you went wrong, but I see two sticky points with your expression for the coefficient of restitution.
1. Why do you say 0.8= vb'-va' /2 ?
The denominator should be 4 - 0 = 4, not 2.
2. If the ball bounces back after the collision, then it must be a negative number and the relative velocity in the numerator becomes the sum of the speeds, not the difference.
Once you have the correct velocities, your method for figuring out the force is correct.
Okay so I tried with the new formula over 4. It was a stupid mistake I made :blushing: thanks for catching it :). But when I recalculated with that change I got a force of -581.8N. I plugged that into the website and it was wrong. Because I had used up all my attempts I found out the answer was 2.62 kN. Unfortunately I'm still lost on how they got that.
The correct eq2 is
vb'-va'=3.2
eq1: va'+10vb'=4
Add them together: 11 vb'=7.2--->vb'=0.6545 m/s.
Calculate the change of momentum of the block, (20*0.6545) divide by the time during the change happened, the result is 2618 N.
ehild
FAQ: Kinetics Problem: Finding average normal force
What is kinetics in physics?
Kinetics in physics is the study of how objects move and the forces that cause them to move. It involves the study of motion, velocity, acceleration, and the forces acting upon objects in motion.
How is average normal force calculated?
The average normal force is calculated by dividing the total normal force acting on an object by the number of contact points between the object and its supporting surface. This is represented mathematically as FN = ΣFN / n, where FN is the total normal force and n is the number of contact points.
What is the significance of finding average normal force?
Average normal force is important in understanding the overall motion and stability of an object. It can help determine the amount of force needed to keep an object in equilibrium or to cause it to accelerate. It is also essential in analyzing the impact of collisions and calculating the work done on an object.
How does average normal force differ from normal force?
The normal force is the force that a surface exerts on an object when the object is in contact with the surface. On the other hand, average normal force is the average value of the normal force over a period of time or over a specific distance. It takes into account any changes in the normal force during that time or distance.
What factors can affect the average normal force?
The average normal force can be affected by the weight and mass of the object, the angle of the surface, the coefficient of friction, and the presence of external forces such as gravity or air resistance. It can also change if the object is in motion or if there are changes in the surface or contact points.
