Kinetics Problem: Head-On Collision Between Two Cars
In summary, the two cars have the same mass, so the energy is 512,5J and from there, multiply it by 0,25 since 75% of the energy is gone and I end up with 128,125J.
Graador
If two cars of equal mass hit each other head on, car A travelling at 25 m/s towards the right and car B travelling at 20 m/s to the left, what will be the speed of each car post-collision if 75% of the energy is lost in bending the metal of the cars.
m1v1 + m2v2 = m1V1 + m2V2
e = Kf/Ki
Since the mass of both vehicles is the same, it's possible to calculate Ki which happens to be 512,5J and from there, multiply it by 0,25 since 75% of the energy is gone and I end up with 128,125J.
Now my problem is that for the velocity, I have: 25,0 + -20,0 = V1 + V2 which is 5,00 = V1 + V2
When I take Kf, I have: 128,125 = V1(sq)/2 + V2(sq)/2 so 256,25 = V1(sq) + V2(sq)
If I try and get the square root, I end up with 16,0 = V1 + V2 which doesn't fit with the first equation which said 5,00 = V1 + V2
After some trial and error, I found that the velocity of the first car is -8,5 m/s and the second 13,5 m/s which when added up, equal 5,00 and when their squares are added up and divided by two, equal 127,25 which is close enough. I just don't understand how to find both velocities from the actual equations themselves because all I find is a quadratic formula that gives me wrong answers.
You will have to solve a system of two equations and two unknowns. This is best done when you first write down equations using symbols, then substitute the numbers after solving the system symbolically. Your energy balance equation seems incorrect.
kuruman said:
You will have to solve a system of two equations and two unknowns. This is best done when you first write down equations using symbols, then substitute the numbers. Your energy balance equation seems incorrect.
So if my energy equation is correct and my first equation is also correct (hard to calculate that one wrong), what am I supposed to do? Is there an equation that I have not considered? I already tried swapping things from on formula to another but they don't equal the same thing for V1 + V2 so that didn't work.
Write down two equations using symbols for the the different quantities that you have. Use different symbols for different quantities. The first equation is momentum conservation, the second equation is the energy balance equation which says that the initial kinetic energy of the cars is equal to the final kinetic energy of the cars plus the energy loss in bending metals. The two unknowns are the final velocities of the cars.
Graador said:
755 of the energy is lost in bending
calculate Kf which happens to be 512,5J
I take it that should be 75%.
You mean Ki, and since you do not know the mass it is 512,5m ms-2, where m is the mass of each car.
##\sqrt{x^2+y^2}\neq x+y## (unless one or both is zero).
This may be simpler in the centre of momentum frame, where you have a symmetry of the motion.
Related to Kinetics Problem: Head-On Collision Between Two Cars
1. What is a head-on collision between two cars?
A head-on collision between two cars occurs when two vehicles traveling in opposite directions collide with each other, typically resulting in significant damage and potential injuries or fatalities.
2. How does the kinetic energy of the cars affect the outcome of a head-on collision?
The kinetic energy of the cars plays a crucial role in the outcome of a head-on collision. The higher the kinetic energy of the cars, the greater the force of impact and potential damage to the vehicles and occupants.
3. What factors influence the kinetic energy of the cars in a head-on collision?
The kinetic energy of the cars in a head-on collision is influenced by factors such as the mass and velocity of the vehicles. The greater the mass and velocity of the cars, the higher the kinetic energy and potential impact force.
4. How can the kinetic energy of a head-on collision be reduced?
The kinetic energy of a head-on collision can be reduced by decreasing the speed of the vehicles involved. This can be achieved through implementing and following speed limits, maintaining safe following distances, and avoiding distracted or impaired driving.
5. What safety measures can be taken to reduce the severity of a head-on collision?
Some safety measures that can help reduce the severity of a head-on collision include wearing seatbelts, having properly functioning airbags, and using advanced safety features such as automatic emergency braking. Additionally, following traffic laws and being aware of potential hazards on the road can also help prevent head-on collisions.
