Kirchoff Rule Sign Conventions, Need Clarity.
In summary: I think you are actually on the right track with your reasoning. Just remember that potential difference is a comparison between two locations, while potential is the value at a single location. Also, potential gradient is simply the rate of change of potential, and is constant within a resistor. In summary, potential and potential difference are related concepts that are often confused. Potential is like elevation and requires a reference point, while potential difference is a comparison between two locations. Potential gradient is the rate of change of potential and is constant within a resistor. When traveling through a source of emf or a resistor, the direction of current flow determines whether the potential difference decreases or increases.
Dgray101
33
Hey all, I am just doing Kirchoffs rules right now. So we have a couple sign conventions we were taught. I just need to make sure my reasoning makes sense for the 3 and 4 rule.
1. When we travel through a source of emf from + --> - we get a - voltage.
2. When we travel through a source of emf from - ---> + we get a + voltage
3 When we travel through a resistor in the same direction as the assumed current we get a -RI because current goes in the same direction as decreasing potential.
4. When we travel through a resistor in the opposite direction as the assumed current, we get a +RI.
So for 3, because we are going in the direction of the assumed current, current always flows from the high potential to the low potential, just as when we consider a positive point charge the potential gradient weakens as we move further away. So the RI term is - which indicates the potential difference at that location is decreasing.
for 4, because we are going opposite the direction of current, we are moving further away from a lower potential difference and closer to a higher potential difference. Like transversing a Potential gradient from infinity to the source, it gets stronger and stronger and the potential is higher.
I really need to make sure my use of potential difference and potential is not convoluted because I tend to misuse the terms.
I have re-ordered your post somewhat, on grounds that it's important to address your last statement first.
And then there is potential gradient as well.
Potential is analogous to elevation, and we can talk about the potential at a specific location. There is the complication that we can add an arbitrary constant to the potential, as long as we add the same constant at all locations. Imagine asking for the elevation at the top of a building: do you mean relative to the ground just outside the building, or relative to sea level? You'll come up with different values for the elevation depending on which reference point is used. So there has to be an implied or understood reference point if you are going to give a numerical value to the potential or elevation at some specific location.
Potential difference (P.D.) means we are comparing the potentials at two locations. It would be nonsensical to talk about the P.D. at a single location -- unless there is some implied or understood reference point that the potential at the location in question is being compared to, in which case we are really talking about the P.D. between the location of interest and the location of the reference point.
(For P.D., that arbitrary-constant-issue we have with potential is no longer an issue, because any constant value added to two locations will cancel when we do the subtraction to calculate the P.D. between those locations.)
Potential gradient is simply the rate of change or slope of the potential, and we can talk about the potential gradient at a single location. (It's equal in magnitude to the electric field, which points toward lower potential.)
Dgray101 said:
So for 3, because we are going in the direction of the assumed current, current always flows from the high potential to the low potential,...
Yes, correct (for resistors anyway).
. . . just as when we consider a positive point charge the potential gradient weakens as we move further away. So the RI term is - which indicates the potential difference at that location is decreasing.
It's more a matter of how the potential itself, not the gradient, is changing. In a typical resistor, the potential gradient is pretty constant -- i.e., the potential itself has a pretty constant slope -- and current is from higher potential "down the slope" to a lower potential.
Actually, it is that we are moving from a lower potential to a higher potential. As I mentioned before, the actual potential gradient (i.e. the slope of the potential) is pretty constant within the resistor material.
Hope that helps.
FAQ: Kirchoff Rule Sign Conventions, Need Clarity.
What are the Kirchoff Rule Sign Conventions?
The Kirchoff Rule Sign Conventions are a set of rules used in circuit analysis to determine the direction and polarity of currents and voltages. These conventions are based on the laws of conservation of energy and charge.
Why is it important to follow the Kirchoff Rule Sign Conventions?
Following the Kirchoff Rule Sign Conventions is important because it ensures accuracy and consistency in circuit analysis. By using these conventions, we can accurately determine the values of currents and voltages in a circuit.
What are the two Kirchoff Rule Sign Conventions?
The two Kirchoff Rule Sign Conventions are the Loop Rule and the Junction Rule. The Loop Rule states that the sum of the voltage drops in a closed loop is equal to the sum of the voltage rises. The Junction Rule states that the sum of the currents entering a junction is equal to the sum of the currents leaving the junction.
How do the Kirchoff Rule Sign Conventions differ from Ohm's Law?
The Kirchoff Rule Sign Conventions and Ohm's Law are two different principles used in circuit analysis. Ohm's Law relates the current, voltage, and resistance in a circuit, while the Kirchoff Rule Sign Conventions focus on the direction and polarity of these quantities.
Can the Kirchoff Rule Sign Conventions be applied to any type of circuit?
Yes, the Kirchoff Rule Sign Conventions can be applied to any type of circuit, whether it is a simple series or parallel circuit, or a more complex network of interconnected components. These conventions are based on fundamental laws of physics and can be used in any circuit analysis.
