Kirchoffs Current Law to find voltage?
The discussion centers on applying Kirchhoff's Current Law (KCL) to solve for voltage in a circuit with dual voltage sources. The original attempt to express the currents through resistors in terms of voltages was deemed incorrect, leading to confusion about isolating the variable VA. Participants emphasized the importance of clearly marking the circuit and defining current directions to avoid sign errors. After refining the equations and applying KCL correctly, the user successfully calculated VA as 6.77V and identified the direction of current flow. The conversation highlights the significance of systematic problem-solving in basic electronics.
TheNarrator
Am having trouble solving the initial part of this problem, I think I am being confused by the dual voltage sources.
2. Homework Equations
I=V/R ΣI at a node =0
V3/R3 - (V1/R1+V2/R2) = 0
V3=12-VA
V1=4-VA
V2=VA-4
However this must be incorrect somewhere as It is impossible to isolate Va from the above equations. Am normally very strong mathematically but find basic electronics very confusing for some reason!
V3=12-VA
V1=4-VA
V2=VA-4
Apply KCL for the node A: that means you express the currents through the resistors R1, R2, R3 in terms of the voltages VA, V1, V2, and then apply the nodal law. Remember, the current flowing through a resistor is proportional to the voltage difference between its terminals.
I understand that part, however I thought that the equations I had put in my attempted solution were in terms of voltage differences and the three voltages? I thought that the way the circuit was laid out, all three voltage differences would be dependant on Va?
Yes. And KCL provides an equation for VA. Do as it is said in the problem.
So what is I1, the current through R1?
What is I2, the current through R2?
What is I, the current through R3?
Likes TheNarrator
You didn't mark up the circuit so it's very hard to work out what you are doing. It doesn't look right. You have terms like V2/R2 which doesn't make sense. V2 is the 12V source on the right hand branch. R2 is a resistor in the middle branch.
Do what others have suggested. Start by marking the circuit with the currents I1, I2, I3 and any voltages you need.
Apply KCL but don't skip the very first step which is to sum the currents. There should be an equation of the form
Ia + Ib + Ic... = 0
Don't go straight to equations with V/R in them.
Likes TheNarrator
Just to add...
It's extremely easy to make trivial sign errors when applying KVC/KCL. It's essential to mark up the diagram because you need to refer to it at the end. For example if a voltage or current turns out to be negative you need to know which direction you defined as positive.
Likes TheNarrator
Thanks for your replies everyone, just at work atm but will mark up the diagram and post my current calculations tonight
This shows what I have attempted, I think where I am going wrong is the way I am doing the voltage differences but I am really struggling to understand specifically where I am going wrong
The currents are right , write up the Nodal Law: them current entering the node is equal to the current leaving it.
Likes TheNarrator
Okay cool, so if i1+i2+i=0
Then (-Va/8)+((Va-4)/6)+((Va-12)/4)=0
But I can't work out how to solve for Va from here, is there another equation I am meant to be using to solve with substitution?
Va is the only unknown. Just collect the terms with Va.
Likes TheNarrator
Oh of course! brain fade..
I calculated Va as 12.57V so therefore i has a value of (12.57-12)/4 = .143A
Thanks for your help!
I will attempt to solve the thevenins problem by myself but will post later if I can't get there
Check it once more. I1 goes into the node, but the other two leave it.
Likes TheNarrator
Okay so now I have (-Va/8)-(Va/6)-(Va/4)=(-4/6)-(12/4)
Which gives Va as 6.77V and a corresponding i of -1.31A
The negative current means i is flowing the opposite way to what I have marked (towards top of diagram)
You didn't define if +ve is into or out of the node.
Is that equation consistent with your diagram (which defines some as +ve going into the Va node and some as leaving)?
If you define +ve as current going into the node then I make it...
I1 + (-I2) + (-I) = 0
or
I1 - I2 - I =0
Correct! Well done!
