Kirkendall effect: vacancy concentration and pair interaction energy
In summary, the equation (1) is a mathematical statement that suggests that the vacancy formation energy in a binary alloy with equal pair-interaction energies is not dependent on the atomic distributions.
always_learning
TL;DR Summary
Relationship between vacancy concentration and pair interaction energy in a core-shell binary spherical nanoparticle on a f.c.c. lattice - where does it come from?
I am reading the following article on Kirkendall effect leading to the Formation of a hollow binary alloy nanosphere: a kinetic montecarlo study. I am unable to understand or find in references the reasoning to obtain equation (1):
Let us consider a kinetic Monte Carlo model of a core-shell binary spherical nanoparticle on a rigid f.c.c. lattice with lattice parameter ##a##, where ##N_A = 45995## atoms of the faster diffuse species A are located in the core with radius ##r_c \sim 14a## whilst ##N_B = 30434## atoms of the slower diffuse species B form the shell with external radius ##r_s \sim 16.58a##. We assume that the three nearest neighbour pair-interaction energies are equal ##\phi_{AA}=\phi_{BB}=\phi_{AB}## but the effective attempt frequencies ##\nu_{A0}## and ##\nu_{B0}## of A and B atoms for exchange with a vacancy are strongly different ##\nu_{A0} / \nu_{B0} =10^3## and do not depend on the local arrangement of a vacancy. This model has a zero enthalpy of mixing. Furthermore, it has been shown [12,14-16] that with an appropriate choice of reduced pair-interaction energy ##\phi/kT## and using the equation:
$$-6\phi/kt \sim \frac{1}{(1-2c_v^{eq})} \ln{\left(\frac{1-c_v^{eq}}{c_v^{eq}}\right)} \quad (1)$$
for a pure element f.c.c. system it is possible to fulfil two requirements necessary for our numerical simulation. These are a reasonable calculation speed and a value of the equilibrium vacancy composition ##c_v^{eq}## sufficiently close to the vacancy composition at the melting temperature ##T_m## of a typical crystalline solid. For the case of very small ##c_v^{eq}## Eq. (1) will correctly describe an equilibrium vacancy composition in a model of a binary alloy with equal pair-interaction energies.
In this case, the vacancy formation energy will not depend on the atomic distributions and the additional configurational entropy term for vacancies appearing in a binary alloy will be negligible (for details see [18]). Following these reasons, the reduced pair-interaction energy ##\phi/kT = -1.5## was chosen using Eq. (1) to provide an equilibrium vacancy composition of ##c_v \sim 1.24×10^{-4}## in pure A and B as well as in a binary A-B alloy of f.c.c. systems.
FAQ: Kirkendall effect: vacancy concentration and pair interaction energy
What is the Kirkendall effect?
The Kirkendall effect is a phenomenon in materials science where there is a difference in diffusion rates between two different components in a solid material. This results in the formation of voids or pores in the material, leading to changes in its microstructure and properties.
How does the Kirkendall effect occur?
The Kirkendall effect occurs due to a difference in the diffusion rates of two different components in a solid material. This can be caused by differences in atomic size, chemical bonding, or temperature gradients within the material.
What is vacancy concentration?
Vacancy concentration refers to the number of vacant lattice sites in a solid material. These vacancies can be caused by defects or imperfections in the material, and can affect its properties and behavior.
What is pair interaction energy?
Pair interaction energy refers to the energy associated with the interaction between two atoms or ions in a solid material. This energy can be influenced by factors such as atomic size, chemical bonding, and temperature, and can play a significant role in the Kirkendall effect.
How does the Kirkendall effect impact materials?
The Kirkendall effect can have significant impacts on the microstructure and properties of materials. It can lead to changes in porosity, grain boundaries, and diffusion pathways, which can affect mechanical, electrical, and chemical properties of the material. Understanding and controlling the Kirkendall effect is important in materials design and engineering.
17K
