MHB Kishan's question via email about an indefinite integral
The discussion focuses on solving the integral of the function (54t - 12) divided by the product of (t - 9) and (t^2 - 2). The recommended method is to use Partial Fractions to decompose the integrand into simpler fractions. The coefficients A, B, and C are determined through substitution, yielding A = 6, B = -3, and C = -3. The final integral solution is expressed in terms of logarithms, ensuring that absolute values are included for each logarithmic term. The solution is confirmed to be correct with the necessary modulus signs in place.
Prove It
MHB
What is the $\displaystyle \begin{align*} \int{ \frac{54\,t - 12}{\left( t- 9 \right) \left( t^2 - 2 \right) } \,\mathrm{d}t } \end{align*}$
We should use Partial Fractions to simplify the integrand. The denominator can be factorised further as $\displaystyle \begin{align*} \int{ \frac{54\,t - 12}{ \left( t - 9 \right) \left( t - \sqrt{2} \right) \left( t + \sqrt{2} \right) } \,\mathrm{d}t } \end{align*}$, so that means the decomposition we should use is
$\displaystyle \begin{align*} \frac{A}{t - 9} + \frac{B}{t - \sqrt{2}} + \frac{C}{t + \sqrt{2}} &\equiv \frac{54\,t - 12}{\left( t - 9 \right) \left( t^2 - 2 \right) } \\ \frac{A\,\left( t - \sqrt{2} \right)\left( t + \sqrt{2} \right) + B\,\left( t - 9 \right) \left( t + \sqrt{2}\right) + C \,\left( t - 9 \right) \left( t - \sqrt{2} \right) }{ \left( t - 9 \right) \left( t - \sqrt{2} \right) \left( t + \sqrt{2} \right) } &\equiv \frac{54\,t - 12}{ \left( t - 9 \right) \left( t - \sqrt{2} \right) \left( t + \sqrt{2} \right) } \\ A\,\left( t - \sqrt{2} \right) \left( t + \sqrt{2} \right) + B \,\left( t - 9 \right) \left( t + \sqrt{2} \right) + C \,\left( t - 9 \right) \left( t - \sqrt{2} \right) &\equiv 54\,t - 12 \end{align*}$
Let $\displaystyle \begin{align*} t = 9 \end{align*}$ and we have $\displaystyle \begin{align*} 79\,A = 474 \implies A = 6 \end{align*}$.
Let $\displaystyle \begin{align*} t = \sqrt{2} \end{align*}$ and we have $\displaystyle \begin{align*} 2\,\sqrt{2} \,\left( \sqrt{2} - 9 \right)\,B = 54\,\sqrt{2} - 12 \implies \left( 4 - 18\,\sqrt{2} \right) \, B = 54\,\sqrt{2} - 12 \implies \left( 4 - 18\,\sqrt{2} \right) \, B = -3\,\left( 4 - 18\,\sqrt{2} \right) \implies B= -3 \end{align*}$.
Let $\displaystyle \begin{align*} t = -\sqrt{2} \end{align*}$ and we have $\displaystyle \begin{align*} -2\,\sqrt{2} \,\left( -\sqrt{2} - 9 \right) \, C = -54\,\sqrt{2} - 12 \implies \left( 4 + 18\,\sqrt{2} \right) \, C = -3\,\left( 4 + 18\,\sqrt{2} \right) \implies C = -3 \end{align*}$
So the integral becomes
$\displaystyle \begin{align*} \int{ \frac{54\,t - 12 }{ \left( t - 9 \right) \left( t - \sqrt{2} \right) \left( t + \sqrt{2} \right) } \,\mathrm{d}t } &= \int{ \left[ \frac{6}{t - 9} - \frac{3}{t - \sqrt{2}} - \frac{3}{t + \sqrt{2}} \right] \,\mathrm{d}t } \\ &= 6\ln{ \left| t - 9 \right| } - 3\ln{ \left| t - \sqrt{2} \right| } - 3\ln{ \left| t + \sqrt{2} \right| } + C \end{align*}$
Mathematics news on Phys.org
This is correct, however are
This is correct, however are you not missing the modulus sign on the last part of your solution? Is it not supposed to be;
$\displaystyle \begin{align*} \int{ \frac{54\,t - 12 }{ \left( t - 9 \right) \left( t - \sqrt{2} \right) \left( t + \sqrt{2} \right) } \,\mathrm{d}t } &= \int{ \left[ \frac{6}{t - 9} - \frac{3}{t - \sqrt{2}} - \frac{3}{t + \sqrt{2}} \right] \,\mathrm{d}t } \\ &= 6\ln{ \left| t - 9 \right| } - 3\ln{ \left|| t - \sqrt{2} \right|| } - 3\ln{ \left|| t + \sqrt{2} \right|| } + C \end{align*}$
The given solution does have absolute value in each logarithm.
##\displaystyle 6\ln{ \left| \,t - 9\, \right| } - 3\ln{ \left| \, t - \sqrt{2} \, \right| } - 3\ln{ \left| \, t + \sqrt{2} \,\right| } + C ##
Noted @SammyS
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
