Klein-Gordon eqn: why dismiss messages at phase velocity
In summary, the superluminal phase velocity of the KG equation is not a problem for relativistic causality because signals travel at the packet/group velocity, which is the inverse of the phase velocity.
AdrianMay
121
Hi All,
I've heard it said that the superluminal phase velocity of the KG eqn is not a problem for relativistic causality because signals travel at the packet/group velocity, which is the inverse of the phase velocity (c being 1). I'm a bit skeptical of this.
We can strip away all the quantum mystique and just consider the (1 dimensional) KG eqn to describe a guitar string with restoring springs along it, or (to put the same thing the other way around) a row of simple harmonic oscillators coupled together. Either way, we can bang on one end with a delta function and watch waves of all wavelengths spread along it at various superluminal speeds including infinity. To convince ourselves that signals can't travel at the phase velocity, we'll somehow have to prove that all those different components add up to zero at every event that's spacelike separated from the impulse. This would seem like a remarkable coincidence - there may be traveling nodes, but zero for the whole continuous spacetime region?
I'm not sure how to type formulae here, but I think I may have proved the opposite. We can consider an event at a spacelike interval from the impulse. Long waves travel faster under KG, so at that event, waves with k from 0 to K will be influencing psi at that event, but the shorter ones won't have arrived yet. We know K because we know that w^2 = k^2 + m^2. I'm not entirely sure what the amplitudes of the components of the Fourier transform of the delta function are when the velocity isn't trivial, but let's just make it a constant. Whatever, you wind up with an integral over k of an exponential of i times something complicated but real. It doesn't really matter that it's complicated. The answer will always be some complex number of a known non-zero magnitude.
Likes atyy
Which is exactly what happens.
This has just been extensively discussed in this thread:
https://www.physicsforums.com/threads/do-tachyons-exist.827961/
Also, if you consider the one-dimensional massless KG equation with an initial condition ##\varphi(x,0)=f(x)## and ##\dot\varphi(x,0)=0## (where the dot denotes the time derivative), then the exact solution is
[tex]\varphi(x,t)=\frac12\bigl[f(x-ct)+f(x+ct)\bigr].[/tex]
So if ##\varphi(x,0)## is zero outside some interval, then ##\varphi(x,t)## remains zero everywhere that is spacelike separated from the interval at time ##t##.
If it's massless I agree that everything travels at c and we have no problem. The massive field is the interesting case.
I read through that thread, but I still don't find an answer. I'm proposing that at t=x=0 I will flip a coin and bang on a KG field with either a positive or a negative delta function. It seems to me that a spacelike separated observer can tell the difference. I see nothing in that thread to say that those "phase-fronts" will all cancel out.
It's a theorem. Wave fronts do not travel faster than light, independent of the mass-squared (positive, negative, or zero).
Does this theorem have a name?
They will. One way to see it is to consider the appropriate Green function, which vanishes outside the light-cone. The appropriate Green function can be expressed as a sum of other "inappropriate" Green functions, so that the terms outside the light-cone cancel out. The full solution of the partial differential equation can be related to the initial condition via the appropriate Green function, so vanishing of the Green function implies also vanishing of the solution.
Of course, mathematically, one can also take a different Green function and in this way obtain a solution which propagates faster than light. However, for such a solution the initial condition is very constrained so the Cauchy problem with arbitrary initial condition is not well posed. In particular, you cannot have a delta-function as an initial condition. Such solutions are generally considered to be unphysical. Typically, the initial conditions related to such solutions cannot even be Fourier expanded.
Likes atyy
Mathematicians usually refer to it as theorems regarding the domain of influence.
Can somebody refer me to some actual maths for this please? I did find the QFT stuff about the Feynman propagator, etc, but that's a totally different model involving a bunch of coupled *quantum* simple harmonic oscillators, whereas the KG equation involves a bunch of coupled *classical* simple harmonic oscillators. I think the psi in the KG equation can be treated as real because even if it was complex, the real and imaginary terms would be independent systems in the absence of any first order diffs to mix them up. Somebody pointed me to the Kramers-Kronig relations but in that case the deal seems to be "If you want a causal Fourier transform then you'll have to tolerate some friction in your system", but the KG equation doesn't have any friction so I guess I'll have to live without the causal Fourier transform. But I still haven't found the maths to prove that those fast waves cancel out in a real, frictionless, 1D, KG system.
That's a nonsense. You can contruct the causal Green function by deforming the contour of integration over frequency, which effectively means that you add an infinitesimal imaginary energy to the theory, which mathematically looks similar to an infinitesimal friction. But this is merely a mathematical trick. You can also construct the causal Green function in a different way, without ever introducing the integration over frequency. Physicsts like the formalism with integration over frequency because that makes the formalism manifestly Lorentz invariant, but in the final expression there is no integration over frequency, only an integral over the spatial wave 3-vector k.
Likes atyy
What you need is to find a proof that the causal Green function vanishes outside the light-cone. It is done in many textbooks. See e.g.
http://nptel.ac.in/courses/115106058/greenfunction.pdf
Eq. (9) and comments on it. For an exercise you can try to evaluate the two terms in (8) separately, and show that each of them treated separately does not vanish outside the lightcone. But outside the lightcone, as shown after (9), their sum is zero.
Likes atyy
That's not really totally different. You can construct the Feynman Green function for classical KG field, and it coincides with Feynman propagator for quantum KG field.
I've seen that kind of thing but it seems both overcomplicated and unsatisfactory. It hits a pole at the one and only point of interest and forces real quantities to be supposed complex for no other reason. So what's wrong with this approach...
$$ \frac{\partial^2 \Psi }{\partial t^2} = \frac{\partial^2 \Psi }{\partial x^2} - m^2 \Psi $$
$$ \Psi(k) = C(k).e^{i(\omega t-kx)} $$
where C is just an amplitude for that mode.
$$ \omega^2 = k^2 + m^2 $$
Phase velocity:
$$ v(k) = \frac{\omega}{k} = \sqrt{1+\frac{m^2}{k^2}} $$
If I hit the origin with a very narrow gaussian impulse, I'll get a flat distribution of wavelengths spreading out in both directions, so ##C(k)## is constant. At an event t=1, x>1 where waves with ## k=K ## have only just arrived:
$$ \Psi(k) = e^{i(\omega t - kx )} = e^{i(\omega - k.v(K) )} $$
$$ \Psi(k) = e^{i(\sqrt{k^2 + m^2} - k.\sqrt{1 + m^2/K^2} )} = e^{ik(\sqrt{1 + m^2/k^2} - \sqrt{1 + m^2/K^2} )} $$
$$ \Psi = \int_0^K dk.e^{ik(\sqrt{1 + m^2/k^2} - \sqrt{1 + m^2/K^2} )} $$
I don't know how to do that integral, but it doesn't look like zero to me. The ##k(\sqrt{1 + m^2/k^2} - \sqrt{1 + m^2/K^2} )## is 0 at ##k=0## and ##k=K## and positive in between. So the exponential heads off from 1 around the Argand plane and then turns around and goes back home. It'll take one hell of a coincidence to make that add up to zero.
BTW, the displacement of the string is the imaginary part of ##\Psi## because that narrow gaussian is an impulse.
That you get zero is indeed subtle from the point of view of these integrals.
As an example, here is an exact solution of the KG equation, valid for ##t>0##:
[tex]\varphi(x,t)=J_0\bigl(m\sqrt{t^2-x^2}\bigr)\theta(t-|x|)[/tex]where ##J_0## is the ordinary Bessel function and ##\theta## is the unit step function. For ##t\ll 1/m##, this is a rectangular pulse (of unit height) that extends from ##x=-t## to ##x=+t##, with its leading edges moving out at the speed of light. Later it turns wavy behind the edges. This solution is the analog of the solution of the wave equation (KG with ##m=0##) of the form ##\theta(x+t)-\theta(x-t)##, which describes a unit height pulse that also expands outward, but with its edges staying sharp forever.
This solution illustrates that local disturbances have leading edges that propagate at the speed of light.
Phase velocity:
Nice try, but your argument contains a subtle and deep error. From your assumption that ##\Psi(t=0)## is a ##\delta##-function it does not follow that ##c(k)={\rm const}##. All what follows is that ##|c(k)|={\rm const}##, i.e.
$$c(k)={\rm const}\, e^{i\varphi(k)}$$
As you may guess, for most choices of the phase function ##\varphi(k)## there will be no cancellation. Yet, it is possible to choose ##\varphi(k)## such that the cancellation really happens.
What does such a special choice of the phase function corresponds to? You required that ##\Psi(t=0)## is a ##\delta##-function, but you said nothing about ##\Pi(t=0)##, where
$$\Pi=d\Psi/dt$$
is the canonical momentum. On the other hand, the KG equation is a second order equation, so you must specify both ##\Psi(t=0)## and ##\Pi(t=0)## to uniquelly determine the solution. In particular, if you want the initial condition to be fully localized, you must require that both ##\Psi(t=0)## and ##\Pi(t=0)## are ##\delta##-functions. But you can easily see that for most choices of the phase function this will not happen. So you must adjust the phase function very carefully to make both initial conditions proportional to a ##\delta##-function. And, the point is, precisely when you make such an adjustement, the wanted cancellation outside the litght-cone will take place.
Likes atyy
@Avodyne: You're telling me things, and I guess you're probably right, but I'm trying to understand where the bug in my logic is.
@Demystifier: I glossed over this, but I did think about it. I'm not requiring that the displacement of the string is a delta function. I'm setting that to zero everywhere. I'm setting the first diff of the displacement to a narrow gaussian. I think that sets my phases - no matter which wavelength, at the origin, the displacement is zero with maximum velocity in the positive direction. I'm reading the displacement off the imaginary part of ##\Psi##. Also, when they say that the FT of a narrow gaussian is a wide gaussian, is it not the case that the phase is determined?
Incidentally, I haven't really justified flattening |##c(k)##|, but I think that we can choose ##K## and ##m## such that the whole ##k(\sqrt{...}...)## expression never exceeds ##\Pi## in which case the contributions to the imaginary part by every mode are all positive (that's if we can nail the phase down as I argued above) and |##c(k)##| wouldn't matter.
You said "If I hit the origin with a very narrow gaussian impulse, I'll get a flat distribution of wavelengths spreading out in both directions". If "narrow" means "narrow in space" , then initial displacement (right after the hit) is a delta function.
Did you perhaps meant "narrow in time, but wide in space"?
It's narrow in space and time. I just whack a point on the string with a little hammer. I keep saying "narrow gaussian" instead of "delta function" because I feel like I know where I am and can just declare the FT to be that wide gaussian, but come to think of it:
$$\delta(x) = \frac{1}{2\pi} \int_{-\infty}^\infty dk.e^{ikx}$$
basically defines ##\delta## as that whose Fourier transform is a constant so it's easier for me. ##x## is a vector including space and time here.
What I'm saying here is intuitively obvious. Suppose you drop a stone in a pond and the long ripples travel faster than the short ones. Suppose also that the water is initially pushed upwards by the stone displacing it. The first wavefronts to arrive are all pushing upwards, and it really doesn't matter exactly which wavelengths arrive when or how the amplitude depends on the wavelength. The maths above is saying merely that, so why expect it to have a flaw?
Then what I said in #15 and #17 can be applied to your case. Your initial impulse picks a special phase function, which in turn is responsible for the cancellation.
If the initial conditions are ##\varphi(x,0)=\delta(x)## and ##\dot\varphi(x,0)=0##, then the solution is
$$\varphi(x,t)=\lim_{K\to\infty}\int_{-K}^{+K}{dk\over 2\pi}\cos(kx)\cos\bigl(\sqrt{k^2+m^2}t\bigr).$$ I haven't been able to find a way to evaluate this integral in closed form (which is quite frustrating). We know that it must vanish for ##|x|>t##, but how to prove this? (Other than the roundabout method of knowing that this is a solution to the KG eq, which must satisfy the domain-of-dependence theorem.)
Likes atyy and Demystifier
Here is the proof.
First take ##|x|>0##, ##t=0##. In this case the integral reduces to
$$\int_{-\infty}^{+\infty}{dk\over 2\pi}\cos(kx)=0 \;\;\; (Eq. 1)$$
Second consider general ##x## and ##t##. Using
$$\cos a \cos b = \frac{1}{2}[\cos(a-b)+\cos(a+b)]$$
it is easy to show that the subintegral function on the right-hand side is Lorentz invariant. (To see that, make also the change of integration variable ##k\rightarrow -k## when useful.)
Third, consider any ##x## and ##t## for which ##|x|>t##. For each such pair ##(x,t)## there is a Lorentz frame ##S'## for which this will mean that ##|x'|>0##, ##t'=0##. We have seen that the subintergral function is Lorentz invariant, so we can calculate it in ##S'##. Thus for each ##(x,t)##, ##|x|>t##, the integral can be reduced to
$$\int_{-\infty}^{+\infty}{dk\over 2\pi}\cos(k'x') \;\;\; (Eq. 2)$$
The measure ##dk## is not Lorentz invariant, so is not equal to ##dk'##. We have a Lorentz transformation
$$k=\gamma(k'-\beta\omega')$$
where ##\gamma## and ##\beta## are constants, while ##\omega'=\sqrt{k'^2+m^2}##. Hence
$$dk=\gamma(dk'-\beta d\omega')$$
so (Eq. 2) above splits into two integrals. One takes the same form as (Eq. 1), so it vanishes. The other is proportional to
$$\int_{-\infty}^{+\infty}{dk'\over 2\pi}{k'\over\sqrt{k'^2+m^2}}\cos(k'x')$$
which vanishes because the subintegral function is anti-symmetric. Therefore (Eq. 2) is zero, which finishes the proof. Q.E.D.
Likes atyy
Alas, this isn't right. When changing integration variables from ##k## to ##k'##, the transformation of the differential is (in general)
$$dk=\left|{\partial k\over\partial k'}\right|dk'$$ You left out the absolute-value sign. When you properly include it, your final integral does not vanish by symmetry.
EDIT: This is wrong! In fact, ##{\partial k/\partial k'}## is always positive, so the absolute-value sign can be safely omitted; see below.
First, for a one-dimensional integral one does not need to take the absolute value because
$$dk={d k\over d k'} dk'$$
without the absolute value. However, one has to be careful because, in general, the limits of integration for ##k## do not need to be the same as those for ##k'##.
Second, in our case this is not really important, because even if one takes the absolute value, one gets the same final result. Taking the absolute value, the integration measure becomes proportional to
$$\left| 1-\beta \frac{k'}{\omega(k')}\right| dk'$$
But we have
$$|\beta|=\frac{v}{c}<1$$
$$\frac{|k'|}{\omega(k')}<1$$
Consequently
$$1-\beta \frac{k'}{\omega(k')}>0$$
so we may write
$$\left| 1-\beta \frac{k'}{\omega(k')}\right| dk' = \left( 1-\beta \frac{k'}{\omega(k')}\right) dk'$$
In this way, even if one takes the absolute value, it doesn't really change the result.
Likes atyy
For pedagogic purposes, let me explain these subtleties in more detail. As the simplest possible case, consider the integral
$$\int_{x=a}^{x=b}dx$$
We assume that ##b>a##, i.e. that the upper limit is larger than the lower limit, which is the standard form of the integral. Consider the change of variable ##x'=-x##. The Jacobian of this transformation is
$$J=\frac{\partial x}{\partial x'}=-1$$
The integral above is equal to
$$\int_{x=a}^{x=b}-dx' = \int_{x'=-a}^{x'=-b}-dx' = \int_{x'=-a}^{x'=-b}J dx'$$
Note that we have ##J## and not ##|J|##. However, we have ##-b<-a##, i.e. the upper limit of integration is not larger than the lower limit, so the integral is not written in the standard form. The standard form is
$$\int_{x'=-b}^{x'=-a}-J dx'=\int_{x'=-b}^{x'=-a}|J| dx'$$
where ##|J|##, rather than ##J##, appears.
This is nothing but a demonstration of the general rule, valid even for multi-dimensional integrals. If all limits of integration are taken in the standard form (the upper limits are larger than the lower limits), then one has to take ##|J|##. (Here ##J## is the determinant of the Jacobian matrix, so ##J## is a real function.) If the limits are not taken in the standard form, then one has to be careful about the ##\pm## sign in front of ##|J|##.
In practice, the standard form is used almost always for multi-dimensional integrals, but not so for one-dimensional integrals.
Likes atyy
You are absolutely right, my objection was not valid! Your proof is good!
Just to answer the question, the thread started with. First of all the problems discussed about the Klein-Gordon equation is exactly an argument for quantizing it. A single-particle wave-function interpretation of relativistic quantum theory (not only for KG but also Dirac and all other wave equations) is inconsistent and thus one uses relativistic QFT as the successful and practical QT in the relativistic realm. The reason is physical: If you have particles colliding at relativistic energies and momenta, you create new particles, and thus you leave the applicability of a strict single-particle theory or a theory with strictly conserved particle numbers. In relativistic QT particle numbers are usually not conserved (except in the case of non-interacting particles) but only net-particle numbers or charges (like electric charge, baryon number, isospin, strangeness in strong interactions etc.). That's why you are naturally lead to a many-body description in terms of Fock spaces.
Second, you can also consider this question in classical electrodynamics, where a classical field limit makes (very important) sense in terms of the Maxwell equations. There you also have relativistic wave equations, and also there nothing prevents either the phase nor the group velocity to be limited by the vacuum speed of light. The only constraint by Einstein causality is that a wave front of a finitely extented wave packet, which has been "switched on" at a finite time cannot exceed the speed of light.
This question came already up more than 100 years ago, when relativity was pretty new: In 1907 Wien asked Sommerfeld, how it can be that in the region of anomalous dispersion of electromagnetic waves, which necessarily occurs in any dielectric material around the resonance frequencies of the bound electrons in the atoms making up the material. There are regions where both the index of refraction become less than 1, leading to a phase velocity ##c_{\text{inmed}}=c_{\text{vac}}{n}>c_{\text{vac}}## as well as the group velocity ##v_{\text{group}}=|\partial \omega/partial \vec{k}|>c_{\text{vac}}##.
Sommerfeld gave a very short answer to this question: There's simply no problem with Einstein causality, because neither of the two sorts of wave speeds describe the propagation of a signal that can transfer information faster than light. The reason lies in the fact that a wave packet in the medium in the time domain is described by a Fourier transform in the frequency domain, and using classical dispersion theory he could show that the wave front can never propagator faster than the speed of light by a quite simple analytical argument in doing the Fourier integral as a contour integral in the complex frequency plane.
This also holds true in relativistic quantum-many body theory, where the linear response theory (Kubo formula) tells you that the perturbations also propagate with the retarded Green's function.
Likes Mentz114
Can you explain how this applies to the integral we've been discussing:
I don't see a "quite simple analytic argument" that shows that this vanishes for ##|x|>|t|##.
In terms of dispersion theory, the KG dispersion relation has branch-point singularities on the real ##\omega## (frequency) axis. This never happens for EM waves in a real-world medium, and so my guess is that Sommerfeld's argument requires analyticity assumptions that don't apply to KG.
This is of course a highly artificial problem and not a physically sensible solution of the KG equation, because it's highly singular and in fact a distribution. Here Sommerfeld's argument cannot be applied, but let's see what can be done for this problem in terms of a distribution-valued (weak) solution.
If I understand it right, you have a (1+1)-dimensional initial-value problem
$$(\partial_t^2-\partial_x^2+m^2)\phi(t,x)=0, \quad \phi(0,x)=\delta(x), \quad \partial_t \phi(0,x)=0.$$
This is most easily solved in the "Mills representation", i.e., introducing the Fourier transform wrt. ##x##:
$$\phi(t,x)=\int \frac{\mathrm{d} k}{(2 \pi)} \tilde{\phi}(t,k) \exp(i k x).$$
Inserting this ansatz into the equation, you find
$$\partial_t^2 \tilde{\phi} =-(k^2+m^2) \tilde{\phi} =-\omega_k^2 \tilde{\phi}.$$
The general solution reads
$$\tilde{\phi}(t,k)=A \exp(-\mathrm{i} \omega_k t)+B \exp(+\mathrm{i} \omega_k t).$$
For ##t=0## we must have ##\tilde{\phi}(0,k)=1##, ##\partial_t \tilde{\phi}(0,k)=0##. From this we find
$$A+B=1, \quad A-B=0 \; \Rightarrow A=B=1/2.$$
This gives
$$\tilde{\phi}(t,k)=\cos(\omega_k t).$$
So we have
$$\phi(t,x)=\int \frac{\mathrm{d} k}{(2 \pi)} \cos(\omega_k t) \exp(\mathrm{i} k x).$$
This is, by the way, the same as was given before, but I'll do another transformation to bring it as close to a covariant expression as I can. Of course, the solution is not manifestly covariant, because the initial condition is defined in a given frame, i.e., at ##t=0## of this frame. Splitting the cos-term into two exponentials and making a substitution ##k \rightarrow -k## in the integral with the ##\exp(\mathrm{i} \omega_k t)## factor one gets
$$\phi(t,x)=\int \frac{\mathrm{d} k}{4 \pi} [\exp(\mathrm{i} \omega_k t -\mathrm{i} k x)+\exp(-\mathrm{i} \omega k t+\mathrm{i} k x)].$$
Now the arguments of the exponentials are invariant under Lorentz transformations. If now ##x^2<t^2##, the Lorentz vector ##(t,x)## is space like. So you can always find a Lorentz boost such that ##t'=0##:
$$\begin{pmatrix} t' \\ x' \end{pmatrix} = \begin{pmatrix} \cosh \eta & -\sinh \eta \\ -\sinh \eta & \cosh \eta \end{pmatrix} \begin{pmatrix} t \\ x \end{pmatrix} = \begin {pmatrix} t \cosh \eta - x \sinh \eta \\ -t \sinh \eta +x \cosh \eta \end{pmatrix}.$$
Now setting ##t'=0## yields
$$\tanh \eta=\frac{x}{t} \in (-1,1),$$
i.e., there is indeed always a real ##\eta## as wanted.
Now the on-shell momentum transforms as well. For the substitution we need the inverse transformation, which you get by substituting ##\eta \rightarrow -\eta## in the Lorentz matrix. The relevant spatial component yields
$$k=\omega_{k'} \sinh \eta + k' \cosh \eta \; \Rightarrow \; \mathrm{d} k=\mathrm{d} k' \left (\frac{k'}{\omega_{k'}} \sinh \eta + \cosh \eta \right ).$$
So doing the substitution yields
$$\phi(t,x)=\int_{\mathbb{R}} \frac{\mathrm{d} k'}{2 \pi} \cos(k' x') \left (\frac{k'}{\omega_{k'}} \sinh \eta + \cosh \eta \right ).$$
Now the first piece vanishes, because the integrand is antisymmetric in ##k'## and the 2nd, because it's ##\propto \delta(x')##, and since ##t^2-x^2=-x'^2 \neq 0##, this also gives 0.
This means ##\phi(t,x)=0## for ##t^2-x^2<0##, as it should be.
Yes, that's a good summary of my solution and Demystifier's proof that it vanishes outside the light cone!
I continue to claim that the inapplicability of Sommerfeld's argument is due to the form of the KG dispersion relation (with branch points on the real axis), and not due to the singular initial condition.
  • #31
vanhees71 said:
Here Sommerfeld's argument cannot be applied ...
It would be nice if you could present details of an example were the Sommerfeld's argument can be applied.
  • #32
I'm not sure what exactly is the Sommerfeld's argument, but there is a very general proof in
A. Bers, R. Fox, C.G. Kuper and S.G. Lipson,
a chapter in the book C.G. Kuper and A. Peres (eds), "Relativity and Gravitation" (Gordon and Breach, 1971)
for which branch points on the real axis are not a problem. The contour of integration over frequency avoids all singularities on the real axis.
  • #33
Demystifier said:
@vanhees71, have you noticed that your proof in #28 is almost identical to my proof in #21?
Argh, I've not seen this posting. It's indeed identical. Sorry for that.
Related to Klein-Gordon eqn: why dismiss messages at phase velocity
1. What is the Klein-Gordon equation?
The Klein-Gordon equation is a relativistic wave equation that describes the behavior of spinless particles, such as scalar bosons. It combines elements of quantum mechanics and special relativity to provide a mathematical description of how these particles move and interact.
2. What is the significance of the phase velocity in the Klein-Gordon equation?
The phase velocity in the Klein-Gordon equation represents the speed at which the wave associated with a particle propagates. It is a fundamental property of the equation and is related to the energy and momentum of the particle.
3. Why is it important to dismiss messages at the phase velocity in the Klein-Gordon equation?
Dismissing messages at the phase velocity is necessary in order to maintain causality in the Klein-Gordon equation. This means that the effect of a particle's motion cannot occur before its cause, which is a fundamental principle in physics.
4. How does dismissing messages at the phase velocity affect the behavior of particles described by the Klein-Gordon equation?
By dismissing messages at the phase velocity, the Klein-Gordon equation ensures that particles cannot travel faster than the speed of light. This is consistent with the principles of special relativity and has important implications for the behavior and interactions of these particles.
5. Are there any other equations or theories that dismiss messages at the phase velocity?
Yes, the Klein-Gordon equation is not the only equation that dismisses messages at the phase velocity. Other equations and theories, such as the Dirac equation and quantum field theory, also incorporate this principle in order to maintain causality and consistency with the principles of special relativity.
