MHB Km8,38 Find the value of \theta if it exists
  • Thread starter Thread starter karush
    Value
The discussion revolves around finding the value of θ for the equation θ = tan⁻¹(√3). It is established that tan(θ) = √3 corresponds to θ = π/3 radians or 60 degrees. A geometric explanation is provided using an equilateral triangle, where the altitude creates two right triangles, confirming that the tangent of the angle opposite the altitude equals √3. The conversation touches on the methods of finding this value, including using calculators or trigonometric tables, but emphasizes the geometric approach. The thread concludes with light-hearted remarks about aging and memory.
karush
MHB
Find the value of $\theta$ if it exists
$$\theta=\tan^{-1}\sqrt{3}$$
rewrite
$$\tan(\theta)=\sqrt{3}$$
using $\displaystyle\tan\theta = \frac{\sin\theta}{\cos\theta}$ then if $\displaystyle\theta = \frac{\pi}{3}$
$$\displaystyle\frac{\sin\theta}{\cos\theta}
=\frac{\frac{\sqrt{3}}{2}}{\frac{1}{2}}
=\sqrt{3}$$ok I think this is a little awkward since it is observing the unit circle to see what will work
so was wondering if there is a more proper way.
Mathematics news on Phys.org
My first thought would be to use a calculator (or, if you are as old as I am, a table of trig functions) but I suspect that is not what you mean. For $tan(\theta)= \sqrt{3}$, imagine an equilateral triangle with all three sides of length 2. Draw a perpendicular from one vertex to the opposite side. That will also bisect the opposites side and bisect the vertex angle. So it divides the equilateral triangle into two right triangles, each with hypotenuse of length 2 and one leg of length 1. By the Pythagorean theorem, The third sides, the altitude of the equilateral triangle, has length $\sqrt{2^2- 1^2}= \sqrt{3}$. So the tangent of the angle opposite that side of length $\sqrt{3}$ is $\frac{\sqrt{3}}{1}= \sqrt{3}$. Of course that angle is one of the original angles of the equilateral triangle so 60 degrees or $\pi/3$ radians.
I'm 74
Just a young guy then! You'd be surprised what geezers most of us are. Nothing else to do, I guess.
we have to let the young (under 70) know our brain didn't implode:rolleyes:
just can't remember a D*** thing anymore...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
