Knee deep in Bayesian statistics and
In summary: The statistical error only exists if you're using the wrong model. It's like when you have a bunch of measurements of height and you fit a model to them and say "well the mean is 5'11" and then you get five people that are 5'10 and you say "well my model sucks, I need to fit a different model". The statistical error exists because you didn't use the right model to begin with. Bayesian statistics doesn't have that problem because you use the right model all the time.
QuantumDefect
64
Hello all,
To just begin, I am having a lot of trouble keeping my brain in the Bayesian view and not letting it revert back to a Frequentist way of thinking. Not to mention having troubles with unbinned MLE estimation. If I say something wrong, please let me know. My questions are as follows:
1) In the Frequentist view, the mean of the distribution of fitted estimators is the true value. If it doesn't match up with your true pseudo-experiment's value, you have a bias and you need to correct for it when you analyze the real experimental data. In the Bayesian view, it doesn't make sense for there to be multiple data sets. How do you test for bias in the Bayesian paradigm?
2) The Bayesian paradigm comes built in with a spiffy way of dealing with systematic uncertainty. You can just allow your unobservable parameter to take all the values within its uncertainty via Monte Carlo and see the resultant spread in your fitted estimator. However when reading papers, it usually gives the estimator in a value plus systematic error plus statistical error format. Does the statistical error even exist in the Bayesian paradigm? The data is what it is and identical experiments don't exist so there is no way of determining a spread in your fitted estimator over many data sets who only vary due to poisson statistics.I'm sure I'll have more questions but those are it for now. I would be greatly appreciative if I could get some help in understanding this. Thanks again!
Bayesianism may be a paradigm change in the sense of Kuhn's The Structure of Scientific Revolutions. Don't hurry through or into it. I found Edwin Thompson Jaynes' Probability Theory: The Logic of Science (2003) a most valuable testbook. Max-ent is a good way of thinking.
I don't understand the format you are talking about. Can you give an example?
Bayesian probability is conditional probability but with a focus on making parameters random variables and deriving lots of results based on that - even for general distributions like the Markov Chain Monte Carlo results (MCMC) that are used in many complicated distribution situations where you have tonnes of random variables with all kinds of assumptions.
If you understand conditional probability well enough (and I mean understand it in a deep way) then Bayesian stuff is straight forward.
The interpretations of probabilities and the philosophy of Bayesian statistics is one thing entirely, but regardless of that the probability framework that includes conditional probability will help you understand the derivations, the results, and basically what the hell is actually going on.
In terms of statistical error you need to understand how the random variable or models involving said random variables are decomposed. You can take for example a Normal distribution and decompose into N = mu + sigma*Z where Z ~ N(0,1). It's a pretty useless decomposition but it is one.
The residual models will have random variables with a particular distribution - which may have its parameters as a random variable as well. Whatever the case is you look at the definition and decide based on that.
Related to Knee deep in Bayesian statistics and
What is Bayesian statistics?
Bayesian statistics is a type of statistical analysis that uses prior knowledge and probability to make inferences about a population or data set. It is based on Bayes' Theorem and is often used in situations where there is uncertainty or incomplete information.
How is Bayesian statistics different from traditional statistics?
Traditional statistics relies on frequentist methods, which assume that the population parameters are fixed and known. In contrast, Bayesian statistics allows for the incorporation of prior knowledge and updates beliefs as new data is collected. It also provides a measure of uncertainty for the results.
What is the advantage of using Bayesian statistics?
One advantage of Bayesian statistics is its ability to incorporate prior knowledge, which can improve the accuracy of results. It also allows for the incorporation of new data as it becomes available, leading to more dynamic and informative analyses.
What are some common applications of Bayesian statistics?
Bayesian statistics is commonly used in fields such as medical research, finance, and engineering. It can be applied in situations where there is uncertainty, such as forecasting, risk assessment, and decision making.
What are some common misconceptions about Bayesian statistics?
One common misconception is that Bayesian statistics is only useful for small data sets. In reality, it can be applied to both small and large data sets. Another misconception is that it is overly complex and difficult to understand. While it can be more nuanced than traditional statistics, with the right resources and understanding, it can be a powerful tool for data analysis.
