MHB Kronecker's Theorem - Anderson and Feil, Theorem 42.1, Chapter 42 .... ....
  • Thread starter Thread starter Math Amateur
    Theorem
The discussion revolves around the proof of Theorem 42.1 from Anderson and Feil's "A First Course in Abstract Algebra," specifically regarding the surjectivity of the function ψ defined from F to F[x]/<p>. The initial concern is that ψ, which is shown to be injective, may not be surjective, as illustrated by an example involving polynomial degrees. The participant questions whether the image of ψ can cover all elements in F[x]/<p>, particularly when considering polynomial remainders. Ultimately, the participant revises their understanding, suggesting that ψ may not be an isomorphism but rather an embedding of F into F[x]/<p>. This reflects a deeper engagement with the material and a recognition of the nuances in the theorem's proof.
Math Amateur
MHB
I am reading Anderson and Feil - A First Course in Abstract Algebra.
I am currently focused on Ch. 42: Field Extensions and Kronecker's Theorem ...
I need some help with an aspect of the proof of Theorem 42.1 ( Kronecker's Theorem) ...
Theorem 42.1 and its proof read as follows:
https://www.physicsforums.com/attachments/6565
https://www.physicsforums.com/attachments/6566In the above text by Anderson and Feil we read the following:
" ... ... We show that there is an isomorphism from $$F$$ into $$F[x] / <p>$$ by considering the function $$\psi \ : \ F \longrightarrow F[x] / <p>$$ defined by $$\psi (a) = <p> + a$$, where $$a \in F$$. ... ... "The authors show that $$\psi$$ is one-to-one or injective but do not show that $$\psi$$ is onto or surjective ...
My question is ... how do we know that $$\psi$$ is surjective ...
... for example if a polynomial in $$F[x]$$, say $$f$$, is degree 5, and $$p$$ is degree 3 then dividing $$f$$ by $$p$$ gives a polynomial remainder $$r$$ of degree 2 ... then $$r + <p>$$ will not be of the form $$<p> + a$$ where $$a \in F$$ ... ... and so it seems that $$\psi$$ is not surjective ... since the coset of $$f$$ is not of the form $$<p> + a$$ where $$a \in F$$ ...
... ?Obviously my thinking is somehow mistaken ...... can anyone help by demonstrating that $$\psi$$ is surjective ... and hence (given that Anderson and Feil have demonstrated it is injective) an isomorphism ...Help will be appreciated ...
Peter
Peter
I probably should not be answering my own question ... but I am now of the opinion that $$\psi$$ is not an isomorphism ... but is an embedding of $$F$$ in $$F[x] / <p>$$ ... I did not read the theorem/proof carefully enough ... :(
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
