Ariel P
- 3
I'm doing the prelab questions which require conceptual questions, not so much of math.
The experiment is a typical ballistic pendulum lab - you'd shoot a paintball twoard a pendulum bob, and you measure the height the pendulum bob reaches after collision to calculate the related velocities.
#1 Define the paintball plus pendulum bob as a system at the instant that the paintball collides with the bob. Do any external forces act on this system?
#2 Will momentum be conserved during the collision? Is any approximation involved?
#3 Will momentum be conserved while the pendulum is swinging? Explain.
#4 Since the velocity and therefore the momentum of the pendulum and ball are zero at the height h (this would be the max height), how can we say that momentum is conserved in the experiment?
#5 Comment on the following statement: "The momentum of the paintball and bob could not be conserved in this experiment because of the large frictional forces between the bob and the entering paintball."
These questions are conceptual I think but relevant equations would be
Pi = Pf
m_ball * v_ball = (m_pend + m_ball) * v_pend
-I'm not so sure what it means by define them as a system...
-I said external forces would be gravity and air resistance (friction)
-I said yes, conserved.
-I'm not sure what it's asking for "approximation"
-I said no because after collision, KE and PE are conserved but momentum is not conserved.
-I first thought it'd be because velocity is continuously lost while the pendulum reaches the top.
-I'm not sure what the correct reasoning would be.
-I'd say the momentum is conserved at the moment they are colliding but not for the entire experiment. Although there are external forces acting (which would bring the ball to stop at max height), just before and after the collision, the momentum of system would be nearly equal as long as the collision interaction is brief.
-If there's no momentum conserved, the bob would remain in its initial position since there's no momentum delivered from the paintball to the bob?
Even partial helps would be greatly appreciated!
Pi = Pf
