Lab Practical Circuit. Find Unknown Resistance.
In summary, the conversation discusses a homework problem involving finding R2 in a circuit by making another voltage measurement and using the known value of R3. The suggested method involves finding the voltage and current of R3 and then using Ohm's law to solve for R2.
pradeepk
So I have to wire the circuit and find R2 by only making another voltage measurement. We know that R3 is equal to 1000 ohms.
So I was thinking that you can find the voltage of R3 and the find the current going through R3. When you have those measurements, you can find the R2 because you know the potential difference by (6-Voltage of R3). Then you use the current found previously, and the ohms law. Is this correct? Thank you
Pradeepk, it would appear that your attachment isn't actually attached.
My apologies..it should work now
Yes, it's fine now.
Your method for finding R2 is okay.
Yes, that sounds like a good approach. You can use Ohm's Law (V=IR) to find the current going through R3, and then use the measured voltage and current values to calculate the resistance of R2. Just make sure to double check your calculations and units to ensure accuracy. Good luck with your lab practical!
FAQ: Lab Practical Circuit. Find Unknown Resistance.
What is a lab practical circuit?
A lab practical circuit is a hands-on experiment where you use electronic components to build and test various circuits to understand how they function and interact with each other.
What is the purpose of finding unknown resistance in a lab practical circuit?
The purpose of finding unknown resistance in a lab practical circuit is to determine the resistance value of a given component or circuit. This information is crucial for designing and troubleshooting circuits.
What tools are needed to find unknown resistance in a lab practical circuit?
The tools needed to find unknown resistance in a lab practical circuit include a power supply, a voltmeter, an ammeter, and a resistor. You may also need a breadboard and various electronic components, depending on the specific circuit being tested.
What is the process for finding unknown resistance in a lab practical circuit?
The process for finding unknown resistance in a lab practical circuit typically involves building the circuit on a breadboard, connecting the power supply, and measuring the voltage and current using the voltmeter and ammeter. The resistance can then be calculated using Ohm's law (R = V/I).
What are some common sources of error when finding unknown resistance in a lab practical circuit?
Some common sources of error when finding unknown resistance in a lab practical circuit include inaccurate measurements due to faulty equipment or human error, temperature changes affecting the resistance of components, and incorrect connections or calculations.
