Lab preperation of Ammonium ferric citrate
  • Thread starter rohanprabhu
  • Tags
    Lab
In summary, the individual is planning to conduct a cyanotype experiment for their chemistry investigative project and requires Ammonium Ferric Citrate, which is not available in their school lab or local retailers. They are seeking advice on how to prepare it in their laboratory using common reagents. The chemical exists in two forms, one with 16.5-18.5% iron, 9% ammonia, and 65% citric acid, and the other with 14.5-16% iron, 7.5% ammonia, and 75% citric acid.
rohanprabhu
414
I have decided to do a a cyanotype experiment for my chemistry investiagtory project, this year in school. To do that, I need Ammonium Ferric Citrate, which my school lab does not stock. Also, local retailers don't have it.
How can i prepare ammonium ferric citrate in my laboratory using common reagents. Some few common chemicals [like citric acid, if required might be available at a local chemicals retailer].
thanks a lot.
Chemistry news on Phys.org
Apparently there are two forms of the stuff:
§ 184.1296 Ferric ammonium citrate.
(a) Ferric ammonium citrate (iron(III) ammonium citrate) is prepared by the reaction of ferric hydroxide with citric acid, followed by treatment with ammonium hydroxide, evaporating, and drying. The resulting product occurs in two forms depending on the stoichiometry of the initial reactants.
(1) Ferric ammonium citrate (iron (III) ammonium citrate, CAS Reg. No. (1332–98–5) is a complex salt of undetermined structure composed of 16.5 to 18.5 percent iron, approximately 9 percent ammonia, and 65 percent citric acid and occurs as reddish brown or garnet red scales or granules or as a brownish-yellowish powder.
(2) Ferric ammonium citrate (iron(III) ammonium citrate, CAS Reg. No.(1333–00–2) is a complex salt of undetermined structure composed of 14.5 to 16 percent iron, approximately 7.5 percent ammonia, and 75 percent citric acid and occurs as thin transparent green scales, as granules, as a powder, or as transparent green crystals.
Preparing ammonium ferric citrate in your laboratory using common reagents is definitely possible. Here is a simple method that you can follow:
Materials:
- Citric acid
- Ammonium hydroxide
- Iron(III) chloride
- Distilled water
- Beakers
- Stirring rod
- Filter paper
- Funnel
- Drying oven
Procedure:
1. In a beaker, dissolve 10g of citric acid in 100mL of distilled water.
2. In another beaker, dissolve 10g of iron(III) chloride in 100mL of distilled water.
3. Slowly add the iron(III) chloride solution to the citric acid solution while stirring continuously.
4. Once all of the iron(III) chloride has been added, slowly add ammonium hydroxide to the mixture while stirring until the solution turns a dark red color.
5. Continue stirring for a few more minutes to ensure complete reaction.
6. Filter the solution using a funnel and filter paper to remove any impurities.
7. Transfer the filtrate to a clean beaker and place it in a drying oven at 100°C until it forms a solid.
8. Once the solid is completely dry, grind it into a fine powder using a mortar and pestle.
9. Your ammonium ferric citrate is now ready to use in your cyanotype experiment.
It is important to note that the amounts of citric acid, iron(III) chloride, and ammonium hydroxide used can be adjusted depending on the desired amount of ammonium ferric citrate needed. Also, make sure to follow proper safety precautions when handling chemicals in the laboratory. Good luck with your experiment!
Related to Lab preperation of Ammonium ferric citrate
1. What is Ammonium ferric citrate used for in the lab?
Ammonium ferric citrate is commonly used in the lab as a chemical reagent for various experiments and reactions. It is also used as a staining agent for biological samples.
2. What are the safety precautions to be taken while handling Ammonium ferric citrate?
It is important to wear proper protective gear, such as gloves and goggles, when handling Ammonium ferric citrate. It should also be stored and disposed of properly according to safety guidelines.
3. How is Ammonium ferric citrate prepared in the lab?
To prepare Ammonium ferric citrate, ferric chloride and citric acid are first dissolved in water. Then, ammonium hydroxide is added to the solution until a precipitate forms. The precipitate is then collected and dried to obtain Ammonium ferric citrate.
4. Can Ammonium ferric citrate be used for quantitative analysis?
Yes, Ammonium ferric citrate can be used for quantitative analysis in the lab. It is commonly used in the determination of phosphorus and as a reducing agent in the Folin-Ciocalteu assay for measuring total phenolic content.
5. Are there any alternative methods for preparing Ammonium ferric citrate?
Yes, there are alternative methods for preparing Ammonium ferric citrate, such as reacting ammonium citrate with ferric nitrate or ammonium ferric sulfate. However, the method using ferric chloride and citric acid is the most commonly used and reliable method.
