I Label propagation equation: what are the terms?
  • I
  • Thread starter Thread starter Master1022
    Propagation Terms
The discussion centers on clarifying the terms in the label propagation equation, specifically equation (2.15). Participants agree that ##f## is a vector, ##S## is a matrix, and ##\alpha## is a scalar, while there is uncertainty about whether ##y## is a vector or scalar. It is suggested that if ##y## were a scalar, it would imply a uniform value across all nodes, which seems unlikely given the context. The consensus leans towards ##y## being a vector, as this aligns with the need for matrix-vector multiplication in the equation. Overall, the terms can be defined as functions of vertices, with ##f## and ##y## represented as vectors over the set of vertices.
Master1022
TL;DR Summary
What terms in the equation (from the linked paper) are vectors or scalars?
Hi,
This is a simple question that I just wanted to clarify. I was reading the following paper on label propagation: HERE and I can't understand whether the terms are vectors or scalars in one of the equations - specifically, equation (2.15) shown in the image below.
My understanding:
- ##f## is a vector
- ## S ## is a matrix
- ## \alpha ## is a scalar
- I am not too sure about ##y##: could be a vector or a scalar.
- ##\nu##: I am not too sure, but I think it could be referring to a specific node? That is, ## f(\nu) ## could be the value of the vector ## f## at node ## \nu ##.
- ## y ##: I am not sure, but I think it is a vector (see reasoning below).
Case is ## y ## is a scalar:
- That would make sense mathematically, but does that mean that we are using the same scalar ## y ## the equation for all nodes. That is, it doesn't matter what node ## \nu ## we are considering, we will always have the same ## y ## scalar in the equation? However, there is another equation above (shown below) which uses y as follows. This suggests that ##y## is a vector because then we have matrix-vector multiplication:
Case if ## y ## is a vector:
- It could be a vector (as suggested by image above), but then we are adding a vector ## (1 - \alpha) y ## to a scalar ## \alpha S f ## is a vector, and we are extracted the value at a certain node ## \nu ##, so it is a scalar. Therefore, it seems unlikely that ## y ## is a vector unless my interpretation of ## \nu ## is incorrect.Apologies if this is sparse with information. I didn't want to rewrite the paper in this post and I am unsure of some of the definitions of variables in there. Any help would be greatly appreciated.
Mathematics news on Phys.org
##f## and ##y## are functions of ##v##, where ##v## designates a vertex, ##S## an operator, ##\alpha## a positive scalar.
For a given set of vertices ##V##, it is possible to write ##f## and ##y## as a vector over the set of vertices, and ##S## as a matrix.
Note that ##y## can't be a scalar otherwise eq. (2.15) would represent the sum of disparate elements.
Many thanks for the response!
So would ## f( \nu ) ## be a vector instead of just referring to the entry of vector ## f## corresponding to ## \nu ##?
I don't understand your question.
##f(v)## is a function, but if you have a discrete set ##V## of vertices ##v##, then ##f(v)## over ##V## can be written as a vector.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
