Labwork Statistics help: Average of averages
The discussion revolves around calculating the average and standard deviation from multiple data points obtained through video analysis of an experiment. Each data point consists of ten repetitions, and the challenge lies in determining the final standard deviation from these averages, which also have their own standard deviations. There is a suggestion to pool the data for a single average instead of performing a two-stage averaging process, although both methods should yield similar results. Additionally, understanding how to calculate the standard error of the mean is emphasized as crucial for accurate error estimation. The conversation highlights the importance of deducing terminal velocity for each run before proceeding with the calculations.
tixi
Find the relationship between velocity and air resistance (experimentally, this is a lab course exercise)
F=mg, F(air)=1/2 p v^2 C(D) A
I have done the experiment, and have a lot of data. For each data point (we have five), we did ten repetitions, for which we need to do video analysis. The analysis works frame by frame and gives a velocity between each frame. So, to get the value of one repetition, we already need to calculate an average that has a standard deviation. THEN, to get the value for that data point, we need to find the average of these ten averages (which we can do since the number of data is the same for every point so they shouldn't be weighted). My issue here is finding the errors. How do I find the final standard deviation for a point that is calculated from 10 values which also all have some standard deviation?
Thank you in advance!
First, are you saying the object is already expected to be at terminal velocity before the first frame?
If so, why do the two-stage averaging? Just pool them and take one average. That said, doing it in two stages should produce much the same result. You understand how to find standard error of the mean?
If not, you first need to deduce the terminal velocity in each run.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
