Lack of Orientation of a Point Mass
In summary, a point mass is a concept in physics that is used to simplify calculations by considering an object as having no orientation and only requiring three coordinates to determine its position. This is in contrast to a rigid body, which requires six coordinates. The concept of a point mass is based on the fact that mass is a scalar and has no orientation. This can be observed by considering the properties of a small sphere and a dumbbell-shaped object, which become more and more similar as they shrink in size. Therefore, a point mass can be thought of as a mass that is so small that its size can be neglected in calculations.
0pt618
25
The point mass (aka particle) is a fictional but useful concept. However, I have yet been able to find a definition of what exactly a point mass is. It is commonly accepted that a point mass does not have an orientation, and thus only 3 coordinates to determine its position are required (as opposed to 6 coordinates required for a rigid body).
Why does a point mass have no orientation? I'd appreciate it if someone can cite a definition of a point mass (if available), and show how this follows from the definition. An intuitive explanation would also be welcome.
No mass has any orientation. Mass is a scalar.
One way to approach the problem would be to consider the properties of a small sphere of mass m and of a pair of small spheres of mass m/2 each, connected by a rod of negligible mass. The gravitational field surrounding the sphere is perfectly uniform outside the sphere and decreases toward zero inside. The gravitational field surrounding the dumbbell-shaped object is not uniform. It is relatively stronger end-on and relatively weaker side-on. The field decreases toward zero near the center of mass.
But suppose that we make both objects smaller and smaller (keeping their mass constant). As they shrink, the gravitational field at a fixed distance from the dumbbell becomes more and more uniform. The region near the center of mass where gravity behaves differently becomes smaller and smaller for both objects. In the limit, one has a uniform gravitational field following an inverse square law everywhere except exactly at the center of mass and an undefined field exactly at the center of mass.
For purposes of gravitational attraction, a "point mass" is the same as a "mass whose size is small enough to be negligible".
Likes 0pt618
Related to Lack of Orientation of a Point Mass
1. What is "lack of orientation" in terms of a point mass?
Lack of orientation refers to the inability of a point mass to have a specific orientation or direction in space. This means that the point mass has no preferred direction of motion or rotation.
2. How does lack of orientation affect the movement of a point mass?
Lack of orientation can lead to unpredictable and random movement of a point mass. Without a specific orientation, the point mass can move in any direction or rotate in any axis, making it difficult to predict its trajectory.
3. Can a point mass have any orientation at all?
No, a point mass is a theoretical concept that has no physical shape or size. It cannot have any orientation as it is considered to be infinitely small and has no defined axis of rotation.
4. What causes a point mass to lack orientation?
A point mass lacks orientation due to its physical properties. As it has no mass or dimensions, it cannot have a defined orientation. Additionally, external forces acting on the point mass can also contribute to its lack of orientation.
5. How is lack of orientation relevant in physics?
Lack of orientation is relevant in physics as it helps simplify certain calculations and models. By assuming a point mass has no orientation, it can be treated as a mathematical point and makes it easier to analyze certain physical systems.
  • Classical Physics
  • Classical Physics
