Aleberto69
- 21
- 1
Hello,
I'm a beginner on SGR and I'm struggeling with this, probably, simple problem.
I'm interested on exploring Field Theory ( relativistic) so I started reading
http://www.elegio.it/mc2/LandauLifshitz_TheClassicalTheoryOfFields_text.pdf
which was suggested and reccomended by a PF's member in another thread as being a very good book.. A sort of reference text.
At page 7-8 the matter of "proper time" is addressed and authors consider the example of a clock arbitray moving.
In order to use the invarinace of interval the authors consider that for short period of time the clock is moving uniformly and so they argument about the possibility of immagining an inertial reference system linked to the clock.
With this assumption they obtain some relevant formulas ( furthermore they also speculate on the fact that if the clock motion is uniform, it is also true that the resting clock appears to the moving clock falling behind too and this because the motion is relative and the two reference inertial, eventually argumenting that there is no contraddiction.)
In other words that means that the observer in one of the two reference knows that the moving clock falls behind, and the observer on the moving clock knows that the clock on the "resting" system is falling behind.
Eventually however they lead to the conclusion that if the clock is moving in a traiectory that after a certain time come back to the original point in the resting system reference, then the moving clock only appears to lag relative to the one at rest.
They argument that it is not possible following the converse resoning in which the movng clock would be considered at rest since the clock describying a closed trajectory does not carry out a uniform rectilinear motion and therefore the linked coordinate system will not be inertial.
MY QUESTION IS:
Why is not possible to use the same argument the authors previously used, that for short interval of time the motion of the clock is uniform and so we can consider an inertial system of coordinate linked to the clock for that short time and then integrate the following results?
In other words, why the authors argument of applying the principle of relativity to an arbitray moving clock just for short ( infinitesimal) lapse of time is not applicable for the converse reasoning?
Many thanks for your help
Aleberto69
MY QUESTION IS:
Aleberto69
