Lagrange Densities: Intuitive Understanding
  • A
  • Thread starter Higgsono
  • Tags
    Lagrange
In summary, the Lagrangian of objects with dimension bigger than zero, such as a string, is found by integrating over a Lagrange density. This may seem unintuitive, but it is similar to the superposition principle when determining the total force on an object. In the case of the Lagrangian, it is the sum of the kinetic and potential energies of each infinitesimal part of the object. This applies to the action as well, even though it may not be obvious at first.
Higgsono
93
I'm a little confused when we transition from the Lagrangian of a point particle to consider Lagrangian of objects with dimension bigger then zero. For instance, the Lagrangian of a string is the sum of the Lagrangians for each infinitesimal part of the object. which means we are integrating over a Lagrange density to get the full Lagrangian. Intuitively I'm not sure why this works. But I think that it's analogous to the situation when we sum up all the forces on the object to determine the total force on the object.
In the case of solving Newton's equation of motion, the superposition principle for the forces seems intuitive, but it is not obvious that it carries over so that the superposition principle applies to the action as well.
The Lagrangian is kinetic - potential energy. You are just finding those quantities for a string. It should be quite clear that the kinetic energy is the sum of the kinetic energies of each part of the string and that the potential of the string is ##S(\ell-\ell_0)##, where ##S## is the tension in the string.
Related to Lagrange Densities: Intuitive Understanding
1. What is a Lagrange density?
A Lagrange density is a mathematical function used in classical mechanics to describe the dynamics of a physical system. It is a function of the system's coordinates and their derivatives, and it encapsulates all the information about the system's potential and kinetic energies.
2. How is a Lagrange density different from a Lagrangian?
A Lagrange density is the integrand of the action functional, while the Lagrangian is the integral of the Lagrange density over time. In other words, the Lagrangian is the time integral of the Lagrange density, and it is used to calculate the equations of motion for a system.
3. What is the role of the Lagrange density in the principle of least action?
The Lagrange density is a key component of the principle of least action, which states that a physical system will follow the path that minimizes the action (the integral of the Lagrangian) between two points in time. The Lagrange density is used to calculate the action and determine the equations of motion for the system.
4. How does the Lagrange density relate to the Lagrange equations?
The Lagrange equations are a set of differential equations that describe the motion of a physical system based on its Lagrangian. The Lagrange density is used to calculate the Lagrangian, which is then used to derive the Lagrange equations. In this way, the Lagrange density is a crucial component in understanding the dynamics of a physical system.
5. Can the Lagrange density be used in other fields besides classical mechanics?
Yes, the concept of a Lagrange density has been extended to other areas of physics, such as quantum field theory and general relativity. In these fields, the Lagrange density plays a similar role in determining the equations of motion for a system, but it may have a different mathematical form depending on the specific field of study.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
