Lagrange equation particle on an inverted cone
In summary, the equations of motion for the system can be derived using cylindrical coordinates and z=\alpha r, and the equation of motion for \phi implies that r^2\dot{\phi}=K where K is a constant. The equation of motion for r can be solved by eliminating \dot{\phi} using this equation.
bobred
173
Derive the equations of motion and show that the equation of motion for [itex]\phi[/itex] implies that [itex]r^2\dot{\phi}=K[/itex] where [itex]K[/itex] is a constant
Using cylindrical coordinates and [itex]z=\alpha r[/itex]
The kinetic and potential energies are
[tex]T=\dfrac{m}{2}\left[\left(1+\alpha^{2}\right)\dot{r}^{2}+r^{2}\dot{\phi}^{2}\right][/tex] and
[tex]V=mg\alpha r[/tex]
The Lagrangian is
[tex]L\left(r,\dot{r},\dot{\phi}\right)=\dfrac{m}{2}\left[\left(1+\alpha^{2}\right)\dot{r}^{2}+r^{2}\dot{\phi}^{2}\right]-mg\alpha r[/tex]
The equation of motion is
[tex]\dfrac{d}{d t}\left(\dfrac{\partial L}{\partial\dot{\mathbf{q}_{k}}}\right)-\dfrac{\partial L}{\partial\mathbf{q}_{k}}=0[/tex]
The equation of motion for [itex]r[/itex]
[tex]\ddot{r}+\alpha^{2}\ddot{r}-r\dot{\phi}^{2}+g\alpha =0[/tex]
The equation of motion for [itex]\phi[/itex]
[tex]r^{2}\dot{\phi}-r^{2}\ddot{\phi} =0[/tex]
Is this correct? If so how does it imply that [itex]r^2\dot{\phi}=K[/itex] is a constant?
Thanks
The Lagrangian is
Thanks
Your ##\phi##-equation is incorrect:
$$\frac{\partial L}{\partial \dot{\phi}} = m r^2 \dot{\phi},$$
so
$$\frac{d}{dt} (m r^2 \dot{\phi}) = \frac{\partial L}{\partial \phi} = 0 .$$
Likes bobred
Hi, got it thanks. Integrating the left hand side gives
[tex]r^2\dot{\phi}=K[/tex]
Meaning I can eliminate [itex]\dot{\phi}[/itex] from the equation of motion for [itex]r[/itex]
Related to Lagrange equation particle on an inverted cone
1. What is the Lagrange equation for a particle on an inverted cone?
The Lagrange equation for a particle on an inverted cone is a mathematical formula used to describe the motion of a particle on the surface of an inverted cone. It is derived from the principle of least action and takes into account the forces acting on the particle, such as gravity and the normal force from the cone's surface.
2. How is the Lagrange equation derived for a particle on an inverted cone?
The Lagrange equation for a particle on an inverted cone is derived using the principle of least action, which states that the path a particle takes between two points is the one that minimizes the action (a measure of the particle's energy) along that path. This principle is applied to the forces acting on the particle on the cone's surface to derive the equation.
3. What are the variables in the Lagrange equation for a particle on an inverted cone?
The Lagrange equation for a particle on an inverted cone has two variables: the position of the particle on the cone's surface, represented by the coordinates (r,θ), and the time (t). The equation also takes into account the particle's mass, the cone's angle, and the forces acting on the particle.
4. How is the Lagrange equation used to analyze the motion of a particle on an inverted cone?
The Lagrange equation for a particle on an inverted cone can be solved to obtain the equations of motion for the particle, which describe how its position and velocity change over time. These equations can be used to analyze the particle's motion and predict its future trajectory on the cone's surface.
5. What are some real-world applications of the Lagrange equation for a particle on an inverted cone?
The Lagrange equation for a particle on an inverted cone has applications in physics and engineering, such as in the analysis of the motion of satellites orbiting a planet or a particle moving on a curved surface. It can also be used to study the stability of inverted cone-shaped structures, such as silos or grain bins. Additionally, the Lagrange equation has been used in the development of control systems for robotic arms and other mechanical systems.
