Xyius
- 508
- 4
EDIT: This is a 2D problem, so all of my ##x## variables should be vectors. I just realized this and it may answer my question, I don't know yet though.
Two masses, ##m_1## and ##m_2## are connected by a massless spring of spring constant ##k##. The spring is at it's equilibrium length and the masses are both at rest; there is no gravitational field. Suddenly, ##m_2## is given a velocity ##v##. Assume that ##v## is so small that the two masses never collide in their subsequent motion. Describe the motion of both masses. What are their maximum and minimum separations?
Lagrange's Equation
COM equations
My professor says that we should use center-of-mass coordinates to make the problem easier (He also says assume the length of the spring is zero). The initial kinetic energy expression is given by,
[tex]T=\frac{1}{2}m_1 \dot{x}_1^2+\frac{1}{2}m_2 \dot{x}_2^2.[/tex]
The center-of-mass transformations are given by,
[tex]\dot{x}_{1,CM}=\dot{x}_1-\dot{X}[/tex]
[tex]\dot{x}_{2,CM}=\dot{x}_2-\dot{X}.[/tex]
Plugging these expressions into the initial expression for kinetic energy and doing some simplification gives me the following.
[tex]T=\frac{1}{2}m_1\dot{x}_{1,CM}^2+\frac{1}{2}m_2\dot{x}_{2,CM}^2+\frac{1}{2}M\dot{X}^2[/tex]
The expression for the potential energy is given by,
[tex]V = \frac{1}{2}k(x_{2}-x_{1})^2[/tex]
Using the same transformation equations on this expression gives the following.
[tex]V = \frac{1}{2}k(x_{2,CM}-x_{1,CM})^2[/tex]
Which makes my Lagrangian equal to,
[tex]\mathcal{L}=T-V=\frac{1}{2}m_1\dot{x}_{1,CM}^2+\frac{1}{2}m_2\dot{x}_{2,CM}^2+\frac{1}{2}M\dot{X}^2-\frac{1}{2}k(x_{2,CM}-x_{1,CM})^2[/tex]
Using Lagrange's equation, I get the three following equations of motion.
[tex]M\ddot{X} = 0[/tex]
[tex]m_1\ddot{x}_{1,CM}=-k (x_{2,CM}-x_{1,CM})[/tex]
[tex]m_2\ddot{x}_{2,CM}=k (x_{2,CM}-x_{1,CM})[/tex]
What is confusing to me is, why is he recommending COM coordinates? If I were to do this problem in laboratory coordinates, would I not get the exact same equations minus the equation for the center-of-mass?? Wouldn't my Lagrangian in that case be,
[tex]\mathcal{L}=T-V=\frac{1}{2}m_1\dot{x}_{1}^2+\frac{1}{2}m_2\dot{x}_{2}^2-\frac{1}{2}k(x_{2}-x_{1})^2?[/tex]
Which yields the same two differential equations for both masses.
