Lagrangian and degrees of freedom
In summary, shounakbhatta says that degrees of freedom for a particle describes the formal state of a physical system. Lagrangian also measures this, right?Lagrangian measures nothing! It is a function which depends on s co-ordinates and s velocities (where s is degrees of freedom). And degrees of freedom for one particle moving in 3D space equals 3 (and not 6)!
shounakbhatta
288
Hello,
I have a very basic question:
Degrees of freedom for a particle describes the formal state of a physical system. Like a particle in 3 dimension space has 3 co-ordinates and if it moves in 3 velocity components, then it has 6 degrees of freedom.
You get 6 degrees of freedom for a _rigid body_: three for linear motion, and three for rotational motion.
Ideal particles don't have any size, so you cannot see them rotate!
Likes 1 person
Degrees of freedom is just the number of independent quantities required to specify in a unique way the position of a particle or a system of particles.When you consider a particle 3 unique numbers are enough to specify its position assuming it is free to move in 3-D space. The number of Lagrange's equation that can be written down for a particle will be equal to the number of degrees of freedom for that particle.
I think I understand what shounakbhatta means. In the Lagrangian formalism, a particle has 6 degrees of freedom. It has 3 for the position and 3 for the velocity. When we specify the functional derivative of the Action to equal zero, we consider variations of the Lagrangian due to purely changes in the velocity and due to purely changes in the position. So the velocity and position of the particle are treated as separate degrees of freedom when we are varying the Lagrangian.
Thank you BruceW, I got it. Is Lagrangian in someway related to General Relativity or Quantum mechanics?
they absolutely love the Lagrangian in quantum field theories. I think there is a Lagrangian for General relativity. But I don't think it is very useful. Much more useful is when quantum field theory is introduced as part of our universe. This is how inflation and symmetry breaking e.t.c. are explained. Look up Andrei Linde "particle physics and inflationary cosmology", pretty interesting. It does assume some knowledge of quantum field theory and general relativity though. I am not able to understand all of it.
Related to Lagrangian and degrees of freedom
1. What is the Lagrangian?
The Lagrangian is a mathematical function that describes the dynamics of a physical system. It takes into account the kinetic and potential energies of the system and can be used to derive the equations of motion.
2. What is the significance of the Lagrangian?
The Lagrangian is significant because it allows for a more elegant and efficient approach to solving problems in mechanics. It also allows for the use of generalized coordinates, making it easier to solve problems in complex systems.
3. What are degrees of freedom?
Degrees of freedom refer to the number of independent variables needed to describe the motion of a system. In other words, it is the minimum number of coordinates required to specify the position of all particles in a system at any given time.
4. How are Lagrangian and degrees of freedom related?
The Lagrangian of a system is dependent on the degrees of freedom, as it is a function of the generalized coordinates used to describe the system. The number of degrees of freedom determines the complexity of the Lagrangian and the equations of motion derived from it.
5. Can Lagrangian and degrees of freedom be applied to all physical systems?
Yes, the Lagrangian and degrees of freedom can be applied to any physical system, as long as the system's dynamics can be described by the principles of classical mechanics. This includes systems ranging from simple pendulums to more complex systems like planetary orbits.
  • Mechanics
