Lagrangian mechanics - rotating rod
The discussion centers on understanding the kinetic energy of a rotating rod, specifically why it includes both translational and rotational components. It highlights that when calculating kinetic energy, the frame of reference affects the consideration of these components, particularly when the rod is fixed at one end. The conversation emphasizes the importance of recognizing the center of mass and how forces like gravity act on the entire mass distribution. A simple beam attached at one end serves as a practical example to illustrate these concepts. Overall, the discussion aims to clarify the physical intuition behind the mathematical formulation of kinetic energy in such systems.
pj33
Hello,
It might sound silly, but when I try to calculate the kinetic energy of a rotating rod to form the Langrangian (and in general), why it has both translational and rotational kinetic energy?
Is it because when I consider the moment of Inertia about the centre I need to include the translational since my "frame of reference" is the centre and it moves but when considering about end I only take into aacount the rotatioal since by "frame of reference" (end of rod) is stationary?
I am looking more for a physical interpretation/intuition.
I hope my explanation above is clear enough!
Thank you in advance!
Likes Dale and Delta2
You talk about a stationary end of rod, so you must have some specific configuration in mind. Can you divulge to us what it is ?
Note that ##\int {1\over 2} {\dot r}^2 \; dm\ ## is the kinetic energy in all cases. Often it is convenient/ useful/ practical to split it up in parts, e.g. as in your c.o.m plus rotation. A force like gravity works on all ##dm## but can comfortably be considered to work on the c.o.m. that way.
All in all nothing physical, just a mathematical approach :wink:
I was just thinking of a simple beam attached at one end at a stationary point.
If I understand this, it helps to tackle harder problems. Thank you!
That is a system with a constraint, so already not all that trivial, but surely instructive.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
