Laminar and steady flow(Distinguish)
In summary: In that case, you need to include the Reynolds stress in your solution to get a valid approximation to Poiseuille's law.
shashank dwivedi
While deriving Poiseuille's law (the relation between flow rate and pressure gradient for fluid flow in a rigid cylindrical tube under a pressure gradient) , we make an assumption that flow is both laminar and steady.Why we need the flow to be laminar. Is it not enough to consider only steady flow?
Is there any connection between these two terms? Is steady flow always laminar ?
I am confused with these terms.
:welcome:
The image shows the difference between laminar and turbulent flows. Both can be consiered steady in terms of volume of fluid per second. But laminar is obviously easier to analyze.
Likes Chestermiller and shashank dwivedi
If you start from the beginning of the derivation of steady, incompressible flow in a pipe without assuming anything about laminar versus turbulent flow, you can come up with the relationship
[tex]\tau_{rz} = \dfrac{r}{2}\left(\dfrac{\partial p}{\partial z}\right).[/tex]
In other words, the pressure gradient in pipe flow is exactly balanced by the shear stress so that you get a steady flow. If you assume the flow is truly steady and therefore laminar, then you just use the relationship for shear stress in a Newtonian fluid to come up with Poiseuille's law:
[tex]\tau_{rz} = \dfrac{r}{2}\left(\dfrac{\partial p}{\partial z}\right) = \mu \dfrac{\partial v_z}{\partial r}.[/tex]
Now, you have to be a little careful here when discussing steady flows. All real fluid flows have some small fluctuating component. One common way to treat this is to recognize that you can break all of your velocity components into a time averaged and a fluctuating component (a process called Reynolds averaging). For example, the ##v_z## component would like like this,
[tex]v_z(r,\theta,z,t) = \bar{v_z}(r,\theta,z) + v_z^{\prime}(r,\theta,z,t).[/tex]
This works as long as the time average of ##v_z##, or ##\bar{v_z}##, is steady over some length of time that you care about. Then, even though the velocities are technically fluctuating, their mean quantities are still steady and you can treat the flow as steady for all intents and purposes. However, by performing this Reynolds averaging, you've also modified your basic Navier-Stokes equations. For a Newtonian fluid, the shear stress tensor now has both viscous and turbulent components and looks something more like this
[tex]\tau_{rz} = \mu\dfrac{\partial \bar{v_z}}{\partial r} - \rho\overline{v_z^{\prime}v_r^{\prime}}.[/tex]
So basically you still have your Newtonian viscous component in the total shear stress, but you now have this new inertial term that shows up that represents a time average of a pair of velocity fluctuation terms. These are typically called Reynolds stresses. This means the solution to the differential equation we started with is now different and is no longer parabolic. It is no longer Poiseuille's law.
Now, I mentioned that no real flow, even a laminar one, is truly without fluctuations. It just turns out that, for a typical laminar flow, the fluctuations are so tiny that the Reynolds stress term is effectively zero and the steady assumption works without any additional stress term. For a turbulent flow, with its characteristic large fluctuations, this is no longer true.
Related to Laminar and steady flow(Distinguish)
1. What is laminar flow and how does it differ from steady flow?
Laminar flow is a type of fluid flow where the fluid moves in smooth, parallel layers with no disruptions or mixing between them. Steady flow, on the other hand, is a type of fluid flow where the velocity and direction of the flow remain constant over time.
2. Can laminar flow become unstable and transition into turbulent flow?
Yes, laminar flow can become unstable and transition into turbulent flow when the velocity of the fluid exceeds a certain threshold, known as the critical Reynolds number. This can also occur when there are disturbances in the flow, such as changes in surface roughness or sudden changes in flow direction.
3. What are some examples of laminar flow in nature?
Some examples of laminar flow in nature include the flow of blood through blood vessels, the flow of air around a smooth sphere, and the flow of water in calm, shallow streams.
4. How is laminar flow different from turbulent flow in terms of energy loss?
Laminar flow has less energy loss compared to turbulent flow. This is because in laminar flow, the fluid particles move smoothly and there are minimal disruptions, resulting in less energy being dissipated. In turbulent flow, there are chaotic movements and mixing of fluid particles, leading to more energy loss.
5. What factors influence the transition from laminar to turbulent flow?
The transition from laminar to turbulent flow can be influenced by a variety of factors, including the velocity of the fluid, the viscosity of the fluid, the surface roughness of the object through which the fluid is flowing, and the geometry of the flow. For example, a larger velocity or a rougher surface can promote the transition to turbulent flow.
  • Thermodynamics
  • General Engineering
  • Classical Physics
  • Other Physics Topics
  • Mechanical Engineering
