SchroedingersLion
- 215
- 57
- TL;DR Summary
- calculation exercise, problems with Ito calculus?
Greetings,
I am struggling with an exercise to the Langevin equation.
Suppose we are given the following differential equation for a particle's 1D time-dependent momentum ##p(t)##:
$$\text{d}p = -\gamma p \text{d}t + F(r)\text{d}t + \sqrt{C\gamma}\text{d}W $$
with a constant ##C##, a position-dependent function ##F(r)##, a friction parameter ##\gamma## and a Wiener process ##W##.
Moreover:
$$ \text{d}r = \frac {p}{m}\text{d}t $$
I am interested in the solution in the limit ##\gamma \rightarrow \infty ##.
In a first step, I am to show that ##p(t)## is given by:
$$p(t)=p(0)e^{-\gamma t} + \int_0^t e^{-\gamma(t-s)}(F(r)+\sqrt{C\gamma}f(t)) \, ds $$
The hint was to first rewrite the differential equation (with a lack of rigor) as ##\frac {dp}{dt} + \gamma p = F(r) + \sqrt{C\gamma}f(t) ##, so apparently ##f(t) = \frac{dW}{dt}##, a random force.
My naive try was now to simply take the time derivative of the given ##p(t)## and show that it suffices the differential equation of the hint. The integral can be calculated analytically, but I don't know what I have to do about the time derivatives of the function ##f(t)##. I get the correct result, aside from terms ~##\frac {d}{dt} f(t)##. Can I assume that these are zero? If the random force is 0 aside from discrete points in time, this might or might not be legit. I might be missing some Ito calculus basics here, so would be happy for a hint.
SL
Moreover:
SL
