Laplace approximation in Bayesian inference
In summary, the conversation discusses the use of Bayesian inference for estimating multiple parameters in a Python project. The Laplace approximation in n-dimensions is suggested for evaluating the evidence, and the formula for calculating the evidence is provided. The speaker is having trouble obtaining the maximum value of the posterior, FX0, for more than 4 parameters and asks for suggestions. A potential solution using corner.py is mentioned.
BRN
108
Hello everybody,
I am working on a Python project in which I have to make Bayesian inference to estimate 4 or more parameters using MCMC.
I also need to evaluate the evidence and I thought to do so through the Laplace approximation in n-dimensions:
$$ E = P(x_0)2\pi^{n/2}|C|^{1/2} $$
Where C is the parameter's covariance matrix and ##P(x_0)## is the maximum value that assumes the posterior.
Getting the covariance matrix is not a problem, but I don't know how get FX0. If they were only 2 parameters I could use matplotlib.hist2d, but being more than 4 parameters...
How could I do?
Some idea?
Thank you!
Technology news on Phys.org
BRN said:
FX0.
What is this ?
Are you looking for something like this
https://corner.readthedocs.io/en/latest/pages/quickstart.html
FAQ: Laplace approximation in Bayesian inference
What is Laplace approximation in Bayesian inference?
Laplace approximation is a method used in Bayesian inference to approximate a complex probability distribution with a simpler one, often a Gaussian distribution. It is based on the Taylor expansion of the logarithm of the original distribution around its mode.
When is Laplace approximation useful in Bayesian inference?
Laplace approximation is useful when the original probability distribution is difficult to work with mathematically, but its mode and curvature can be easily determined. It is also useful when the original distribution is multi-modal, as it can approximate each mode separately.
How accurate is Laplace approximation compared to other methods?
Laplace approximation is known to be a good approximation for unimodal distributions, as it captures the shape and location of the distribution well. However, it may not be as accurate for distributions with multiple modes or heavy tails.
What are the limitations of Laplace approximation?
Laplace approximation relies on the assumption that the original distribution is well-approximated by a Gaussian near its mode. Therefore, it may not be accurate for highly skewed or asymmetric distributions. Additionally, it does not provide any information about the tails of the distribution.
How is Laplace approximation implemented in practice?
In practice, Laplace approximation involves calculating the mode and curvature of the logarithm of the original distribution, then using these values to approximate the original distribution with a Gaussian. This can be done analytically for some distributions, but may require numerical optimization for others.
