Laplace Equation, Non-Concentric Spheres
In summary: Overall, this problem highlights the importance of thorough testing and collaboration in scientific research.In summary, the conversation discussed a problem involving eccentric spheres and a general solution for it. The solution involved a series of Legendre polynomials and unknown coefficients. However, when the offset (a) was greater than zero, the solution diverged in the region where radii r<a. To improve the solution, steps such as checking for errors in the equations, testing for convergence, and exploring other numerical methods were suggested. It was also recommended to consult with other experts for their insights and suggestions. Overall, this problem highlights the importance of thorough testing and collaboration in scientific research.
gparker267
1. Homework Statement
General solution for eccentric spheres, smaller sphere (radius, b) completely embedded within larger sphere of radius c. The centers of both spheres lie on z-axis, distance a, apart (note: c>b+a). Problem is symmetric, so consider θ=[0,∏], r=[0,c]. The inner sphere is grounded while the outer sphere is held at a potential f(c,θ).
2. Homework Equations
General solution (see Morse & Feshbach, 1953) is given in coordinates of larger sphere as:
V(r,θ)=Ʃ1((r/a)^s×Ʃ2(A_n×(a/b)^n×[(-1)^(n-s)n!/s!(n-s)!])-(a/r)^(s+1)×Ʃ3(A_n×(b/a)^(n+1)×[s!/n!(s-n)!]))P_s(cosθ)
V(c,θ)=f(c,θ), θ=[0,∏], r=[0,c]
Limits of summations
Ʃ1, s=0 to s=s_max (can use s_max=50)
Ʃ2, n=s to n=n_max (can use n_max=50)
Ʃ3, n=0 to s=s
3. The Attempt at a Solution
I have expanded the boundary function, f(c,θ) as a series of Legendre polynomials and computed the unknown coefficients A_n. For the special case when the offset (a) is zero,the solution behaves well (and converges nicely to prescribed boundary conditions, BCs). However, in cases where the offset is greater than zero, the solution diverges in the region where radii r<a. Any ideas on what might be going wrong?
I would suggest the following steps to troubleshoot and improve the solution for this problem:
1. Check for errors in the equations: Double check all equations and make sure they are correctly written and accounted for. It is possible that a small error in one of the equations could lead to the divergent behavior.
2. Test for convergence: Run the solution for different values of s_max and n_max and see if the solution converges to the prescribed boundary conditions as these values increase. If the solution does not converge, it could indicate an issue with the equations or the numerical method being used.
3. Consider different boundary conditions: Instead of using a general function for f(c,θ), try using specific boundary conditions such as a constant potential or a linear potential. This can help identify if the issue lies in the boundary function or the general solution itself.
4. Explore other numerical methods: It is possible that the numerical method being used is not suitable for this particular problem. Consider using other methods such as finite element or finite difference methods to see if they provide a more accurate and stable solution.
5. Consult with other experts: Reach out to other scientists or experts in the field for their insights and suggestions. They may have encountered similar problems and can offer valuable advice on how to improve the solution.
In conclusion, troubleshooting and improving a solution for a complex problem like this requires a systematic approach and a lot of patience. By carefully examining the equations and testing different options, it is possible to find a more accurate and stable solution.
Related to Laplace Equation, Non-Concentric Spheres
What is the Laplace Equation?
The Laplace equation is a partial differential equation that describes the distribution of a scalar field in a given region. It is commonly used in physics and engineering to model various phenomena, such as heat flow, electrostatics, and fluid dynamics.
What are non-concentric spheres?
Non-concentric spheres are spheres that do not share the same center point. In other words, their centers are not aligned, and they do not have the same radius. These spheres can have different sizes and orientations relative to each other.
How is the Laplace Equation used to solve problems involving non-concentric spheres?
The Laplace equation can be solved analytically or numerically to determine the distribution of a scalar field between non-concentric spheres. This can be useful in studying various physical phenomena, such as the electric potential between two charged spheres or the temperature distribution in a system of non-concentric spheres.
What are some real-world applications of the Laplace Equation for non-concentric spheres?
The Laplace equation for non-concentric spheres has a wide range of applications in various fields, including electrical engineering, fluid mechanics, and heat transfer. Some specific examples include modeling the potential between two electrodes in an electric circuit, predicting the flow of fluid around a rotating sphere, and analyzing the temperature distribution in a heat exchanger.
Are there any limitations to using the Laplace Equation for non-concentric spheres?
While the Laplace equation is a powerful tool for solving problems involving non-concentric spheres, it does have some limitations. One major limitation is that it assumes a steady-state condition, meaning that the system is not changing over time. Additionally, it may not accurately model certain complex systems or systems with irregular boundaries.
  • Differential Equations
