Laplace Transform Notational Question
In summary, the conversation discusses using the Laplace transform to find the solution to a given problem, with all initial conditions being zero. The solution involves taking the Laplace of both sides and using the unit step function to denote u(t). The confusion arises from treating the function y(t) differently from u(t).
Saladsamurai
3,020
Given: [tex]\frac{d^2y}{dt^2} + 12\frac{dy}{dt} + 32y = 32u(t)[/tex]
and that all initial conditions are zero, use the Laplace transform to find y(t)
This is an example problem from my text. They start the solution by taking the Laplace of both sides assuing y'(0) = 0 & y(0) = 0 :
[tex]s^2Y(s) + 12sY(s) + 32Y(s) = \frac{32}{s}[/tex]
I am just a little confused why [itex]L[32y] = Y(s)[/itex] but [itex]L[32u(t)] = 32/s[/itex]
y is a function of time, so why is y(t) treated differently from u(t)?
I know this is probably a stupid question...sorry :redface:
~Casey
Sorry! I think I got it! I just found in my notes that some texts denote the 'unit step function' u(t). Where u(t) = 1 for t >0 and u(t) = 0 for t<=0.
Poop!
FAQ: Laplace Transform Notational Question
What is the Laplace Transform?
The Laplace Transform is a mathematical tool used to convert a function from the time domain to the frequency domain. It is often used in engineering and science to solve differential equations and analyze systems.
How is the Laplace Transform denoted?
The Laplace Transform is denoted by the symbol ∫{f(t)} = F(s), where f(t) is the function in the time domain, F(s) is the function in the frequency domain, and s is the complex variable.
What is the difference between the Laplace Transform and the Fourier Transform?
The Laplace Transform is a generalization of the Fourier Transform, which only applies to functions that are of infinite duration. The Laplace Transform can be used on functions with finite duration and can handle more complex functions, such as those with discontinuities and exponential growth.
What are the advantages of using the Laplace Transform?
The Laplace Transform allows for the solution of differential equations by converting them into algebraic equations in the frequency domain. It also simplifies the analysis of systems, as it can handle complex functions and provides a more intuitive understanding of their behavior.
Are there any limitations to using the Laplace Transform?
The Laplace Transform is limited to functions that are absolutely integrable, meaning that they do not grow too quickly or have infinite values. It also cannot be used for functions that have a singularity at the origin, as the integral diverges at that point.
