Laplace transforms; Abel's integral equation
In summary, the conversation discusses using Laplace transforms to find the solution of Abel's integral equation, which involves a Laplace convolution. The transform of g(x) is found to be \sqrt{\frac{p}{\pi}}(\frac{1}{p}+\frac{1}{p^2}+\frac{2}{p^3}) , with the inverse transform of the first term being known. The other two transforms cannot be solved using a Bromwich contour.
bdforbes
152
Using Laplace transforms, find the solution of Abel's integral equation:
[tex]\int^{x}_{0}\frac{f(u)}{\sqrt{x-u}}du = 1 + x + x^2 [/tex]
I recognized that the integral is a Laplace convolution, leading to:
[tex] (f*g)(x) = 1+x+x^2 [/tex]
where [tex] g(x)=x^{-1/2}[/tex]
So:
[tex] L(f*g)=L(1)+L(x)+L(x^2)[/tex]
[tex] L(f)L(g)=\frac{1}{p}+\frac{1}{p^2}+\frac{2}{p^3}[/tex]
I can't figure out the transform of g(x). I tried contour integration in the first quadrant, indenting around the origin and placing the branch cut along the negative real axis, and I got to this:
[tex] L(g)=\int^{\infty}_{0}\frac{e^{-px}}{\sqrt{x}}dx=i\int^{\infty}_{0}\frac{e^{-ipx}}{\sqrt{ix}}dx[/tex]
Can anyone help me solve this last integral, or suggest another way to find the transform?
Okay, I realized that I was making it too complicated by trying contour integration. I saw the change of variables x=y^2 for L(g), and got L(g)=sqrt(pi/p).
So now I'm left with:
[tex] L(f) = \sqrt{\frac{p}{\pi}}(\frac{1}{p}+\frac{1}{p^2}+\frac{2}{p^3}) [/tex]
[tex] = \pi^{-1/2}(p^{-1/2}+p^{-3/2}+2p^{-5/2}) [/tex]
Obviously I now know the inverse transform of the first term. The other two I can't get. I tried Bromwich contour integration, but the branch cut presents some difficulties there. Any ideas?
I found the other transforms using some guesswork. I guess they can't be solved using a Bromwich contour, which to me has some interesting meta-mathematical implications.
FAQ: Laplace transforms; Abel's integral equation
What is a Laplace transform?
A Laplace transform is a mathematical operation that converts a function of time into a function of complex frequency, allowing for the analysis of systems in the frequency domain. It is commonly used in engineering and physics applications.
How is a Laplace transform calculated?
The Laplace transform is calculated by integrating the function of interest multiplied by the exponential function e^(-st), where s is a complex parameter known as the Laplace variable. The resulting integral is then evaluated from 0 to infinity.
What is Abel's integral equation?
Abel's integral equation is a type of integral equation that involves an unknown function in both the integrand and limits of integration. It is named after the mathematician Niels Henrik Abel and is used in various fields of mathematics and physics.
How is Abel's integral equation solved?
The solution to Abel's integral equation involves applying a Laplace transform to both sides of the equation and then solving for the transformed function. The inverse Laplace transform is then applied to obtain the solution in terms of the original function.
What are some applications of Laplace transforms and Abel's integral equation?
Laplace transforms and Abel's integral equation have various applications in mathematics, engineering, and physics. They are commonly used in control systems, circuit analysis, signal processing, and solving differential equations. Additionally, they are used in the study of heat transfer, fluid mechanics, and quantum mechanics.
