DreamWeaver
- 303
I should state, from the outset, that this tutorial is NOT going to go into any great detail about the theory and applications of Laplace transforms. Some of the aforementioned will be discussed in a cursory way, but the aim here is merely to provide a selection of proofs for common transforms. That said, on with the show...Throughout, I will use the notation\(\displaystyle F(w) = \mathfrak{L}(f) = \int_{0}^{\infty} e^{-wx}f(x)\, dx\)and\(\displaystyle f(w) = \mathfrak{L}^{-1}(F)\)NOTE:In the field of Laplace transforms, it is standard practice to use "s" rather than the "w" I will use here. Consider the following expressions of the same transform:\(\displaystyle F(w) = \mathfrak{L}(f) = \int_{0}^{\infty} e^{-wx}f(x)\, dx\)\(\displaystyle F(s) = \mathfrak{L}(f) = \int_{0}^{\infty} e^{-sx}f(x)\, dx\)Personally, I think that superscript of "s" in the second example is far less legible than the equivalent "w" in the first. Hence me using "w" throughout this thread.----------------
Proposition 01:
----------------Let \(\displaystyle f(x)=1\) (the unit constant), then\(\displaystyle \mathfrak{L}(1) = \int_0^{\infty} e^{-wx}dx = \frac{1}{w} \)Proof:\(\displaystyle \mathfrak{L}(1) = \int_0^{\infty} e^{-wx}dx = -\frac{1}{w}\, e^{-wx}\, \Bigg|_0^{\infty}\)Hence when \(\displaystyle w>0\) this becomes\(\displaystyle -\frac{1}{w}\, \left[ \lim_{z\to \infty} e^{-z} - \lim_{z\to 0} e^{-z}\right] = -\frac{1}{w}\, \left[ \frac{1}{e^{\infty}} - \frac{1}{e^0} \right] = \frac{1}{w}\)As was to be shown. \(\displaystyle \Box\)
Proposition 02:
----------------Linearity of the Laplace transform: Let \(\displaystyle a\) and \(\displaystyle b\) be scalar constants, and \(\displaystyle f\) and \(\displaystyle g\) be functions of the variable, then:
\(\displaystyle \mathfrak{L}(a\, f +b\, g) = a\, \mathfrak{L}(f) + b\, \mathfrak{L}(g)\)This follows directly from the linearity of integrals:
\(\displaystyle \int (a\, f(x) + b\, g(x) )\, dx = a\, \int f(x)\, dx + b\, \int g(x)\, dx. \, \Box\)
Proposition 03:
----------------Let \(\displaystyle x \ge 0\), then when \(\displaystyle f(x)=e^{ax}\), and \(\displaystyle w-a>0\):\(\displaystyle \mathfrak{L}(e^{ax}) = \frac{1}{w-a}\)Proof:\(\displaystyle \mathfrak{L}(e^{ax}) = \int_0^{\infty} e^{ax}e^{-wx}\, dx = \int_0^{\infty} e^{-(w-a)x}\, dx=\)\(\displaystyle -\frac{1}{(w-a)}e^{-(w-a)x}\, \Bigg|_0^{\infty} = \frac{1}{w-a}\)Provided \(\displaystyle w-a > 0\). The proposition is now proved. \(\displaystyle \Box\)
Proposition 01:
Proposition 02:
Proposition 03:
