Laplace Transforms: Transfer Functions and Impulse
In summary: Is this correct?In summary, the conversation discusses solving a Laplace transform problem involving impulse and unit step functions. The transfer functions are found to be the same, and the Laplace transforms of the functions are calculated. The function for wind force is determined to be 4.5N from 1 to 10 seconds, and the problem is left at the point of needing to plot the given function. The final function for wind force is f(t) = 1160δ(t-4) + 935δ(t-6) + 708δ(t-7.8) + 4.5(u(t-1) - u(t-10)).
ConnorM
79
I uploaded the question as a picture and attached it.
Unit step function -
[itex]u_c (t) =
\begin{cases}
1 & \text{if } t \geq c \\
0 & \text{if } t < c
\end{cases}[/itex]
Impulse function -
[itex] δ(t) = \displaystyle\lim_{Δ\rightarrow 0} δ_Δ (t)[/itex]
Multiplication Property for Impulse function -
[itex] f(t)⋅δ(t - t_d) = f(t_d)⋅δ(t - t_d)[/itex]
*A function [itex]f(t)[/itex] becomes a value [itex]f(t_d)[/itex]*
(a and b)
I have determined that both of the transfer functions are the same,
[itex] H(s) = V(s)/F_{p / w}(s) = {\frac{1}{75s + 0.0046}} [/itex]
(c)
The Laplace transform of the impulse function is 1 so,
[itex] V(s) = {\frac{1}{75s + 0.0046}} [/itex]
[itex] v(t) = {\frac{1}{75}} e^{{\frac{-0.0046}{75}}t} [/itex]
(d)
The Laplace transform of the unit step function is 1/s so,
[itex] V(s) = {\frac{1}{s(75s + 0.0046)}} [/itex]
[itex] v(t) = 217.391 - 217.391 e^{{\frac{-0.0046}{75}}t} [/itex]
***Am I right up to this point?***
(e)
[itex]f_{wind} (t) =
\begin{cases}
4.5 & \text{if }1 \geq t < 10 \\
0 & \text{otherwise,}
\end{cases}[/itex]
Does that mean that from 1 -> 10 there is a constant force of only 4.5N? That just seems negligible compared to the force applied by the skaters pushes.
[itex] f(t) = f_{wind}(t) + 1160δ(t-4) + 935δ(t-6) + 708δ(t-7.8) [/itex]
Not quite sure how to model this!
[itex]u_c (t) =
\begin{cases}
\end{cases}[/itex]
Impulse function -
(a and b)
(c)
(d)
Assuming units of m/sec, this seems way too large. Can you show what you did in going from V(s) to v(t)? There's a partial fractions decomposition involved.
(e)
\begin{cases}
\end{cases}[/itex]
You have a typo: The first case restriction is ##1 \le t < 10##
I can't write them out right now since I'm on my phone. I just checked them on wolfram alpha and it gave the same answer.
[itex]u_c (t) =
\begin{cases}
\end{cases}[/itex]
Impulse function -
(a and b)
(c)
(d)
(e)
\begin{cases}
4.5 & \text{if }1 \le t < 10 \\
\end{cases}[/itex]
Ok I have fixed the function, [itex]f_{wind}(t)[/itex].
For,
Partial Fraction Decomp.
[itex] V(s) = A/s + B/(75s + 0.0046) [/itex]
[itex] 1 = A(75s + 0.0046) + B(s) [/itex]
subbing in s = 0,
[itex] A = 1/0.0046 = 217.391 [/itex]
subbing in s = -0.0046/75
[itex] 1 = B(-0.0046/75) [/itex]
[itex] B = -75/0.0046 [/itex]
[itex] V(s) = 217.391/s + (-75/0.0046)/(75s + 0.0046) [/itex]
[itex] v(t) = 217.391 - 217.391e^{-0.0046/75} [/itex]
Could someone help me with part 5e? I'm not sure how to plot this.
Here is what I have so far,
[itex]f(t) = 1160dirac(t-4) + 935dirac(t-6) + 708dirac(t-7.8) + 4.5(u(t-1) - u(t-10))[/itex]
Related to Laplace Transforms: Transfer Functions and Impulse
1. What is a Laplace transform?
A Laplace transform is a mathematical tool used to analyze and solve differential equations in the time domain. It transforms a function of time into a function of complex frequency, making it easier to solve problems involving differential equations.
2. How is a Laplace transform different from a Fourier transform?
A Laplace transform is similar to a Fourier transform, but it includes a damping term that takes into account the system's response to initial conditions. This makes it more useful for analyzing systems with initial values or transients, while a Fourier transform is better for analyzing steady-state behavior.
3. What is a transfer function and how is it related to Laplace transforms?
A transfer function is a mathematical representation of the relationship between the input and output of a system. It is obtained by taking the Laplace transform of the system's differential equation. Transfer functions are used to analyze the behavior of systems in the frequency domain.
4. What is an impulse response and how is it related to Laplace transforms?
An impulse response is the output of a system when an impulse (a brief, high-intensity input) is applied. It is obtained by taking the inverse Laplace transform of the system's transfer function. It is useful for understanding a system's behavior and for designing filters and control systems.
5. How are Laplace transforms used in engineering and science?
Laplace transforms are widely used in engineering and science for solving and analyzing problems involving differential equations. They are particularly useful in electrical engineering for analyzing circuits, in control systems for designing controllers, and in signal processing for filtering and analyzing signals. They are also used in other fields such as physics, chemistry, and economics.
