Large VEVs in SUSY gauge theories
In summary: Summary: In summary, the semi-classical methods used in the derivation of the ADS superpotential for SQCD with N_f<N_c involve matching the scales of the high- and low-energy theories, taking into account the large VEVs that break the gauge symmetry at a high scale. These methods are reliable even at strong coupling due to the inclusion of non-perturbative effects.
vev
Hi
N=1 supersymmetric gauge theories usually have moduli spaces of vacua that are parametrized by vacuum expectation values of the scalar components of chiral superfieds. Often these are lifted quantum mechanically due to non-perturbative effects.
For example in the lectures hep-th/9509066 on p. 12 it is mentioned that giving large VEVs to the fields will break gauge symmetry at a high scale where the (asymptotically free) theory is weakly coupled and where semi-classical methods are reliable. But where exactly are these semi-classical methods in the following derivation of the ADS superpotential for SQCD with N_f<N_c? Is it just that the scales of the high- and low energy theories can be matched by a one-loop calculation (p. 14)? The unbroken gauge group is strongly coupled at low energies, no matter how large the VEVs were.
Thanks and best regards,
vev
Dear vev,
Thank you for your question. The semi-classical methods in the derivation of the ADS superpotential for SQCD with N_f<N_c are indeed based on matching the scales of the high- and low-energy theories. This is possible because at high energies, the theory is weakly coupled and can be described using semi-classical methods, while at low energies, the theory is strongly coupled and requires non-perturbative techniques.
In this context, the large VEVs of the fields play a crucial role in breaking the gauge symmetry at a high scale, where the theory is weakly coupled and semi-classical methods are applicable. This allows us to match the scales of the high- and low-energy theories, and use semi-classical techniques to derive the ADS superpotential.
Furthermore, the unbroken gauge group being strongly coupled at low energies does not affect the validity of the semi-classical methods used in the derivation of the ADS superpotential. This is because the non-perturbative effects that lift the moduli space of vacua are taken into account in the calculation, making the result reliable even at strong coupling.
I hope this helps clarify the role of semi-classical methods in the derivation of the ADS superpotential for SQCD with N_f<N_c. If you have any further questions, please don't hesitate to ask.
Related to Large VEVs in SUSY gauge theories
What are Large VEVs in SUSY gauge theories?
Large VEVs, or vacuum expectation values, in SUSY (supersymmetric) gauge theories refer to the spontaneous breaking of supersymmetry in a vacuum state. This results in the appearance of large VEVs for scalar fields, which are responsible for giving mass to particles in the theory.
Why are Large VEVs important in SUSY gauge theories?
Large VEVs play a crucial role in SUSY gauge theories because they allow for the cancellation of quantum corrections to the Higgs mass, which is known as the "hierarchy problem". This is one of the main motivations for incorporating supersymmetry into particle physics theories.
What is the relationship between Large VEVs and the Higgs mechanism?
The Higgs mechanism is a crucial part of the Standard Model of particle physics, and it is also present in SUSY gauge theories. In both cases, it is responsible for giving mass to particles through the generation of VEVs for scalar fields. However, in SUSY gauge theories, the large VEVs are related to the spontaneous breaking of supersymmetry, whereas in the Standard Model, the VEVs are related to the breaking of electroweak symmetry.
Are there any experimental implications of Large VEVs in SUSY gauge theories?
Yes, there are potential experimental implications of large VEVs in SUSY gauge theories. One possibility is the production of new particles with masses on the order of the VEVs, which could be detected at high-energy particle colliders such as the Large Hadron Collider (LHC).
What are some current research directions related to Large VEVs in SUSY gauge theories?
Some current research directions include the study of large VEVs in specific SUSY models, the search for experimental evidence of these VEVs, and the investigation of the implications of large VEVs for cosmology and dark matter. Additionally, there is ongoing research on the possibility of breaking supersymmetry in a way that does not require large VEVs, which could also have important implications for particle physics.
  • Beyond the Standard Models
11K
