SimonBuk
- 2
Hi, I'm new to the site so I hope I'm in the right place, I have a question regarding gears for a project that I am working on at uni.
I'm designing a building which has a steam driven turbine at the base, what I want to have is levels above which are attached to the same axle as the turbine but spin a lot slower. The obvious way to run this is to involve a gear system for which I made a model below. This used a simple gear that I took out of a cheap clock. So the model works on a 1:12 Ratio
However, A Steam Turbine can turn at approx 5000RPM, I would like the levels above to turn at a rate of approx 1 rotation and hour, which is about 0.02RPM I think?
Is anything like this possible, its obliviously a massive step down. The building has a 20m diameter so a lot of space is available if massive gears are required. But where do I start with working out how it would work, would a planetary gear system support it?
Any help or advice on this would be greatly appreciated!
Thanks
Simon
Thanks
Simon
