Laser Beam Destructive Interference
In summary, two beams of light will not destructively interfere if they are directed in opposite directions and have the same amplitude.
GRB 080319B
108
If two lasers are pointed emitting end to emitting end in a vacuum (for lowest divergence), and emit 2 beams of light 180 out of phase, could both beams destructively interfere completely (no light coming from either emitting end after the beams converge)? If the experiment was done under conditions where some of the laser light could scatter, would a "shadow" propagate from the point of convergence to the emitting ends of the lasers (assuming the lasers are far enough apart where this can be reasonably detected)? Where would the energy of the beam go (heat?), assuming the lasers continue to function after the beams converge? Would beams travel into the emitting end of the the opposing laser and interfere with the gain medium?
Science news on Phys.org
If two beams are directed in opposite directions and have the same amplitude, in the gap between the lasers' ends will be a standing wave, like in a resonator. In this case the 180 degree phase shift can be established only for points in this gap, standing apart on a half wavelength. For other points it will change between 0 and 180. So, no destruction of the wave picture in the gap, but lasers may be destroyed.
Unless the two lasers were mutually coherent, no interference would occur. A simpler experiment is to use a laser with a very long coherence length, split the beam and create a ring cavity. In this case, there is a standing wave pattern. Even so, it's not clear what would happen- some of the light would re-enter the laser cavity and alter the lasing characteristics.
Right. Destructive interference does not imply that the waves cease to propagate.
This is important and a common misconception.
Related to Laser Beam Destructive Interference
What is laser beam destructive interference?
Laser beam destructive interference is a phenomenon that occurs when two or more laser beams meet at a certain point and cancel each other out, resulting in a decrease in the overall intensity of the laser beams.
How does laser beam destructive interference work?
Laser beam destructive interference occurs when two or more laser beams with the same wavelength and frequency meet and interfere with each other. This interference causes the peaks and troughs of the waves to align, resulting in cancellation of the waves.
What are the practical applications of laser beam destructive interference?
Laser beam destructive interference has various applications in fields such as optics, telecommunications, and holography. It is often used to create interference patterns and improve the resolution of optical instruments.
What factors affect laser beam destructive interference?
The intensity, wavelength, and angle of the laser beams are the main factors that affect laser beam destructive interference. Other factors such as the medium through which the beams travel and the distance between the beams can also play a role.
How can we control or manipulate laser beam destructive interference?
Laser beam destructive interference can be controlled by adjusting the intensity, wavelength, or angle of the laser beams. It can also be manipulated by introducing a medium with a different refractive index or by changing the distance between the beams.
  • Optics
  • Optics
  • Atomic and Condensed Matter
