Laser beam with 5 millimeter diameter
In summary, to get a smaller spot size with a laser beam, you can either use a lens with a shorter focal length or increase the size of your collimated beam before focusing it with a lens. The exact method depends on your desired spot size and wavelength.
sml2010
Hi
Please help me to know : if i have a laser beam with 5 millimeter diameter that reduced to 0.5 millimeter diameter with a lens, Can i reduced the 0.5 millimeter diameter beam to 0.05 or less that 0.5 with another the same lens?
https://www.physicsforums.com/attachment.php?attachmentid=60563&stc=1&d=1375041919
What distance do you suggest between these two lenses?
I am waiting for your help.
Thank you
Science news on Phys.org
Wait. It is not that easy. By just placing one lens, you will focus the beam. That means you will get a very small spot at a single position and afterwards it will spread again. Do you want a small spot at some position or do you want a small collimated beam?
If you want a collimated beam, you need to build something like a telescope. You place the first lens will focus the beam at the focal distance of the first lens. Now you place the second lens in a distance to the focal spot which equals the focal length of the second lens. If you do it right, you will again get a collimated beam with a different diameter. The magnification (or demagnification) is then simply given by focal length of lens 1 divided by the focal length of lens 2.
So you want a lens with long focal length placed first and another lens with short focal length (placed at a distance equal to the sum of the focal lengths away from each other) to get a small diameter collimated beam starting from a larger diameter collimated beam.
hi dear Cthugha
thank you for your reply.
I only need a very small spot at a single position, the laser beam in my focus distance heated big zone (near 1.2 mm) but i want have a laser beam with 0.2 mm heated zone.
I am looking for a method to have a small spot beam to have a smaller heated zone.
Do you know any other method to get smaller spot beam?
I am wait for your reply.
thank you
The minimal spot size you can get, can be calculated via Gaussian optics (https://en.wikipedia.org/wiki/Gaussian_beam).
In a nutshell, there are two main ways to get a small spot:
1) Use a length with short focal length. The shorter your focal length is, the smaller the spot can be. If you need really small spots, a microscope objective may help. However, this is typically only an issue if you want spots sizes on the order of less than ten micrometers. 0.2 mm does not sound too bad. What wavelength are you working with? Shorter wavelengths make it easier to get small spots.
2) Use a broad collimated beam. What a lens does is essentially a Fourier transform. To get a small spot, you need to have a lot of different momenta present. You can achieve this by having a large collimated beam before the lens. So if using a short focal length lens alone is not sufficient, building a telescope to get a broader collimated beam before focusing it down might help.
for your question. The answer depends on the specific properties of the lenses and the laser beam. In general, it is possible to further reduce the diameter of the laser beam with another lens, but it will depend on the focal length and other parameters of the lens. The distance between the lenses will also play a role in the final diameter of the beam. It is recommended to consult with a specialist in optics to determine the best setup for your specific experiment.
FAQ: Laser beam with 5 millimeter diameter
What is the purpose of using a laser beam with 5 millimeter diameter?
A laser beam with 5 millimeter diameter is typically used for precision cutting, welding, and drilling in industrial applications. It can also be used for medical procedures and scientific research.
How is the diameter of a laser beam measured?
The diameter of a laser beam is measured by using a beam profiler, which is a device that captures an image of the beam and calculates its size and shape.
Can the diameter of a laser beam be adjusted?
Yes, the diameter of a laser beam can be adjusted by using lenses or mirrors to focus or expand the beam. This allows for versatility in its use for different applications.
What type of laser is typically used for a 5 millimeter diameter beam?
A solid-state laser, such as a neodymium-doped yttrium aluminum garnet (Nd:YAG) laser, is commonly used for creating a 5 millimeter diameter beam. These lasers have high power and can produce a small, focused beam.
Are there any safety precautions to consider when using a laser beam with 5 millimeter diameter?
Yes, laser beams can be hazardous to the eyes and skin. It is important to wear proper eye protection and follow safety protocols when working with a laser beam of any size. Training and supervision are also recommended for safe operation.
