Laser Communications in Outer Space
In summary, NASA's Lunar Probe will use lasers to communicate high resolution images and data from the Earth to the probe for faster comms. Error-correcting codes play an important role there, and the distance depends on the laser quality, power, wavelength, receiver telescope quality, data rate and many other factors. The limit is the data rate.
bodykey
46
I just saw an article regarding NASA's Lunar Probe that will use lasers to communicate high resolution images and data from the Earth to the probe for faster comms.
My question is...in Outer Space with no atmospheric influence, at what distance would laser communications like this remain fully accurate (no loss of data)?
Astronomy news on Phys.org
There is no "fully accurate", but you can reduce the risk to something like "on average 1 bit per 1 million years of data transmission", where you don't care about the hypothetical probability of this any more.
Error-correcting codes play an important role there.
The distance depends on the laser quality, power, wavelength, receiver telescope quality, data rate and many other factors.
We have been bouncing lasers off the moon for over 40 years now [re: Lunar Laser Ranging Experiment]. The data quality is sufficient for incredibly precise measurements.
So it would be safe to say that several bursts of lasers containing quantum information could be successfully transmitted without much of a flaw over say a 10 AU distance and received on the other end by another satellite?
What exactly do you mean with "quantum information"? Do you want to share entangled photon pairs? That will lead to a very low efficiency for reasonable designs.
Just sending classical data is way easier, as you can send many photons, it does not matter if 99.999% (or more) are lost if you have enough of them.
I just mean information, similar to the way that fiber optics send information along fiber cables. In pulses that are represented as zero's and one's.
That is not quantum information.
Transmitting data over a distance of 10 AU is possible, the data rate depends on sender and receiver.
I suppose my more core question is, what is the limit of such communication? If 10 AU is possible, what about 100 AU, or 1,000 AU?
You can transmit data to other planetary systems, light years away (where 1 light year is ~63 000 AU). You just won't achieve the same data rate as in the communication with a satellite orbiting earth.
Likes 1 person
Ok, gotcha. Thanks :)
Related to Laser Communications in Outer Space
What is laser communication in outer space?
Laser communication in outer space is a method of transmitting data and information using laser beams between two points in space. It is a form of free-space optical communication and is becoming increasingly popular due to its high data transmission rates and low power consumption.
How does laser communication in outer space work?
Laser communication in outer space works by using a laser transmitter to send a beam of light towards a receiver located on a spacecraft or satellite. The receiver then detects the light and converts it into data, which can be used for various purposes such as communication, navigation, and scientific research.
What are the advantages of using laser communication in outer space?
There are several advantages of using laser communication in outer space. These include higher data transmission rates, lower power consumption, and a more secure and reliable connection compared to traditional radio frequency communication. Laser communication also allows for smaller and lighter communication systems, making it ideal for use in space.
What are the challenges of using laser communication in outer space?
One of the main challenges of using laser communication in outer space is the need for a clear line of sight between the transmitter and receiver. This can be difficult to achieve in certain situations, such as when there is interference from other objects in space or during adverse weather conditions. Another challenge is the potential for signal degradation due to atmospheric turbulence.
What is the future of laser communication in outer space?
The future of laser communication in outer space looks promising, with the technology continuously improving and becoming more widely adopted. It is expected to play a crucial role in future space missions, including deep space exploration and the establishment of a global network for space-based communication. There is also ongoing research and development to address the current challenges and further enhance the capabilities of laser communication in outer space.
