[Laser] Inversion number above and below threshold
This results in a decrease in the photon flux, which can be expressed as F = F0e^(-R/R0), where F0 is the photon flux at R = 0 and R0 is a characteristic pump rate.In summary, for a 3-level laser, the occupation numbers N1 and N2, the inversion ΔN/N, and the photon flux F can be expressed as a function of the pump rate R, with different equations for above and below the threshold. I hope this helps!
ApexOfDE
123
Consider a 3-level laser. Give the occupation numbers N1(R), N2(R), the inversion [tex]\Delta[/tex]N(R)/N = [N2(R) - N1(R)]/N and the flux below and above the threshold as a function of pump rate R.
F - the photon flux
I have written down the total rate equation for N1, N2 and F:
[tex]\frac{dN1}{dt} = -RN1 + T21N2 + \sigma F(N2 - N1)[/tex]
[tex]\frac{dN2}{dt} = RN1 - T21N2 - \sigma F(N2 - N1)[/tex]
[tex]\frac{dF}{dt} = \sigma F(N2 - N1) + T21N2 - F/ \tau[/tex]
[tex]\sigma[/tex] = the absorption cross section
T21 = the spontaneous emission rate from 2 to 1
[tex]\tau[/tex] = the resonator decay rate
In steady state, all rhs of these eqs are equal to zero. Above the threshold the amplification factor remains constant. I get stucked here. Can someone give me a hint or an idea so that I can solve it?
Thx in advance
Hello there,
I would first start by defining all the variables and parameters in the given equations. This will help us understand the physical meaning of each term and how they relate to the system.
N1 and N2 are the population numbers in levels 1 and 2, respectively. These are related to the total population N by the equation N = N1 + N2.
R is the pump rate, which represents the rate at which energy is being pumped into the system.
T21 is the spontaneous emission rate from level 2 to level 1. This is the rate at which photons are emitted without any external stimulation.
σ is the absorption cross section, which represents the probability of a photon being absorbed by the system.
F is the photon flux, which is the rate at which photons are passing through a unit area.
τ is the resonator decay rate, which represents the rate at which photons are lost from the system due to leakage or absorption.
Now, in steady state, as you correctly mentioned, all the right-hand sides of the equations are equal to zero. This means that the rates of change of N1, N2, and F are all zero, and their values remain constant.
Above the threshold, the amplification factor remains constant, meaning that the rate at which photons are being emitted from level 2 to level 1 is equal to the rate at which they are being absorbed by the system. This can be expressed as T21N2 = σF(N2 - N1).
Using this relationship, we can solve for N1 and N2 in terms of the other parameters:
N1 = N2 - Fσ/2T21
N2 = N - N1 = N - N2 + Fσ/2T21
Substituting these expressions into the equation for the inversion ΔN/N, we get:
ΔN/N = [N2(R) - N1(R)]/N = [N - N2 + Fσ/2T21 - (N2 - Fσ/2T21)]/N = Fσ/(NT21)
Similarly, we can solve for the photon flux F as a function of the pump rate R:
F = 2RT21/(σ + 2T21τ)
Below the threshold, the amplification factor is less than 1, meaning that the rate of photon emission from level 2 to level 1 is less than the rate
Related to [Laser] Inversion number above and below threshold
What is laser inversion number?
Laser inversion number is a term used in laser physics to describe the number of excited atoms or molecules in a laser material. It is typically denoted by the symbol N and is an important factor in determining the efficiency and output power of a laser.
What is the significance of laser inversion number?
The laser inversion number is significant because it determines the population distribution of the atoms or molecules in the laser material. A higher inversion number means that there are more excited atoms or molecules available to produce light, resulting in a higher laser output power.
What is the difference between inversion number above and below threshold?
Inversion number above and below threshold refers to the state of the laser material in relation to its lasing threshold. Above threshold, the laser material has a higher inversion number and is producing stimulated emission, resulting in a coherent laser beam. Below threshold, the inversion number is lower and the laser material is not producing enough stimulated emission to sustain a coherent beam.
How does the laser inversion number affect laser performance?
The laser inversion number is a critical factor in determining the performance of a laser. A higher inversion number leads to a higher output power and a more efficient laser. It also affects the lasing threshold, with a higher inversion number requiring less energy to reach threshold and produce a coherent beam.
What factors can affect the laser inversion number?
The laser inversion number can be affected by a variety of factors, including the pumping rate, the temperature of the laser material, and the type of laser material used. These factors can impact the population distribution of excited atoms or molecules and therefore affect the inversion number and the performance of the laser.
