Laser Physics: Steady state gain
In summary, steady state gain is a measure of light amplification in a laser cavity at a constant rate. It is calculated by comparing output power to input power and is affected by factors such as laser medium, pump power, and optical losses. Steady state gain plays a crucial role in determining laser performance and can be optimized by selecting the right medium, adjusting pump power, and minimizing losses in the cavity.
Niles
1,866
Hi
In almost every book on photonics I've seen, the following expression for the steady state gain is derived
1 + flux/fluxsaturation = gsmall signal/g,
where I by flux mean intracavity flux and g is the gain. When talking about lasers, then in the very same books (e.g. Saleh/Teich) the authors argue that when lasing begins, the intracavity photon flux increases, hence by the above expression the gain decreases until it settles on its steady state value (which is equal to losses). What I find to be confusing is that the above expression only holds for steady state, but Saleh/Teich (and others) use it to argue that gain decreases until it reaches steady state.
How can they use our steady state expression above to describe the dynamical behavior too?
Niles.
Science news on Phys.org
Dear Niles,
Thank you for bringing up this interesting topic. The expression you mentioned for steady state gain is indeed a commonly used one in photonics literature. However, I understand your confusion about its application in the dynamical behavior of lasers. Let me try to explain it further.
In the steady state, the gain of a laser is equal to its losses, as you correctly pointed out. This means that the intracavity flux is balanced by the losses, resulting in a constant gain value. Now, when the laser is first turned on, the intracavity flux is initially low and the gain is higher than the losses. This causes the intracavity flux to increase, as more photons are being generated by the gain medium. However, as the intracavity flux increases, the gain starts to decrease due to the saturation effect. This decrease in gain eventually balances out with the increasing losses, resulting in a steady state gain value.
So, although the expression you mentioned is for steady state gain, it can also be used to describe the initial dynamics of a laser. This is because the decrease in gain and increase in intracavity flux are happening simultaneously, until they reach a steady state. I hope this clarifies your confusion. If you have any further questions, please don't hesitate to ask.
Related to Laser Physics: Steady state gain
1. What is steady state gain in laser physics?
Steady state gain is a measure of the amplification of light within a laser cavity at a constant rate. It is an important factor in determining the output power and stability of a laser.
2. How is steady state gain calculated?
Steady state gain is calculated by taking the ratio of the output power to the input power in a laser cavity. It can also be calculated by measuring the population inversion and the photon lifetime within the laser medium.
3. What factors affect steady state gain in lasers?
The main factors that affect steady state gain in lasers include the type of laser medium, the pump power, and the optical losses within the cavity. The geometry and design of the laser cavity can also have an impact on the steady state gain.
4. How does steady state gain affect laser performance?
Steady state gain plays a crucial role in determining the output power and stability of a laser. Higher steady state gain can lead to higher output power, but it can also cause instabilities and decrease the overall efficiency of the laser.
5. How can steady state gain be optimized in lasers?
Steady state gain can be optimized by carefully selecting the laser medium, adjusting the pump power, and minimizing optical losses within the cavity. The design and geometry of the laser cavity can also be optimized for better steady state gain and overall laser performance.
  • Atomic and Condensed Matter
  • General Engineering
