Laser that doesn't have a resonator?
In summary: However, I believe it is possible to have a laser without a resonator, as demonstrated by nitrogen lasers. In summary, it would appear that it is possible to have a laser without a resonator, but practical use is not currently known.
girlinphysics
25
Is it possible to have a laser without a resonator? My guess is you can as you would still get some proportion of light coming from the inverted medium. My question is how would this light be different (from that of a laser with a resonator) and are there any practical uses for such a device?
Science news on Phys.org
It would appear so. The following Wikipedia article has a reference for a single pass nitrogen laser (ref 9) which does not have a resonant cavity.
https://en.wikipedia.org/wiki/Laser i.e. "Nitrogen Laser". Light and Its Uses. Scientific American. June 1974. pp. 40–43. ISBN0-7167-1185-0.
I can’t see how that would work. The high Q of the resonator is what gives laser light its temporal coherence. Without the resonator all you would have is spontaneous emission plus a bit of amplified spontaneous emission (ASE).
Daz
Have a look at the Wikipedia article. I haven't yet tracked down the Sci. Am. article from 1974 to see whether it casts any light on the matter. I too originally thought that a cavity resonator was essential for laser operation,. The Wiki article does mention use of a mirror at one end but no half silvered mirror at the exit end. I guess the Light Amplification by Stimulated Emission is the critical part that can take place without the cavity as long as the population inversion is achieved by pumping. The efficiency and spatial and temporal coherence are no doubt improved by a high Q cavity. I'll ask a few colleagues who work on laser physics for their insights. I might try a search for papers on lasers without cavities and see what turns up.
Interesting - thanks Dave. I clicked through onto the Nitrogen laser page where it says they work on the superluminescence principle. Superluminescence is just ASE but the gain is so high you can get a useable beam without a cavity.
One of the references on that page was this, with lots of info on N2 lasers:
http://www.repairfaq.org/sam/lasercn2.htm
It seems that the lower lasing level in N2 is metastable so it wouldn’t work CW and the gas is pumped by an arc discharge which is too brief to establish resonance in a cavity anyway. So people just leave out the mirrors and get a bright beam of ASE with each discharge.
That page above claims it’s coherent, but I can’t get my head around that. Any ideas?
As mentioned above, solid state lasers can be highly lossy because the gain is also high- they essentially function as single-pass amplifiers. There are also unstable resonator designs which can be used in high power applications.
Related to Laser that doesn't have a resonator?
1. What is a laser without a resonator?
A laser without a resonator is a type of laser that does not rely on a resonator cavity to produce a laser beam. Instead, it uses a different mechanism, such as a gain medium or external feedback, to generate a coherent beam of light.
2. How does a laser without a resonator work?
A laser without a resonator works by using a gain medium, which is a material that amplifies light, to produce photons. The photons are then reflected or amplified by external factors, such as mirrors or feedback from the environment, to create a coherent beam of light.
3. What are the advantages of a laser without a resonator?
Some advantages of a laser without a resonator include a more compact size, lower cost, and increased versatility. They can also operate at higher power levels and have a wider range of wavelengths compared to traditional resonator-based lasers.
4. What are the applications of a laser without a resonator?
Lasers without a resonator have a variety of applications in fields such as telecommunications, materials processing, and medical procedures. They are also used in scientific research and military technology.
5. Are there any limitations to a laser without a resonator?
One limitation of a laser without a resonator is that it may not produce a highly collimated beam like traditional lasers. This can affect its precision and accuracy in certain applications. Additionally, they may be more susceptible to external disturbances or fluctuations in the environment.
  • Optics
  • Optics
  • Electrical Engineering
  • Atomic and Condensed Matter
