Lasers can be used to ionize air....
  • Thread starter Sven Andersson
  • Tags
    Air Lasers
In summary, the conversation discusses the use of lasers for ionization, specifically of hydrogen or deuterium gas. The question is raised about what kind of laser light would be most effective and cost-efficient for this purpose, with suggestions for green or violet lasers or even a strong UV-lamp. The potential for using a pulsed laser for high field strength is also mentioned. The conversation ends with a question about the relation between optical pumping power for 3-level and 4-level lasers.
Sven Andersson
38
By surfing the net I learned that lasers can be used to ionize air and even produce "bangs" for some reason. Now, what I'm after is to ionize hydrogen or deuterium gas, at either 1 atm pressure or reduced pressure, say 40 mbar. Now what kind of laser light would be best to use? A hideously strong green laser perhaps? Or a strong 405 nm laser? Which is cheapest per watt laser light? UV lasers are probably too expensive. What about using a strong UV-lamp?
There are apparently two ways for ionization; either multiphoton or some sort of resonance of the electrons in the changing electric field of the laser light; now which applies to ionization of hydrogen or deuterium?
All input welcome!
Infrared CO2 lasers at high power probably, that doesn't mean it has to be the best for ionization.
What is the application of your ionization? How much do you want to ionize? Is there any other gas present apart from hydrogen?
Do you want to ionize hydrogen molecules or hydrogen atoms? The first happens at significantly lower energies, but then you'll probably get a mixture of ionized molecules and free (non-ionized) atoms.
Primarily I want deuterons or protons. Also I want them as "cold" as possible too. It doesn't matter if there are other species present also such as D, D2+, even D-.
Soft X-rays could do the job best perhaps. They even sell soft X-ray generators for ionizing air to remove static electricity.
The question is if a very strong green or violet laser could do the job too, reasonably efficiently? Actually testing it yourself may be the only way of finding out.
Multi-photon ionization requires huge intensities. Ionization of hydrogen needs 13.6 eV, so even for two-photon ionization you would need a laser with 7 eV. With 3-4 eV you need 4-5 photons, which makes the rate even lower.
An x-ray source might be interesting. I have no idea how well an electron beam would work.
It is possible to make a plasma by heating a small volume in the laser focus, not sure if that would give a relevant ionization rate for hydrogen.
It's not the beam intensity per se that matters, but the peak field strength. In practice that means using a pulsed laser. Typically, the average beam power will be quite small but even a quite modest average power corresponds to enormous field strength if all the energy is squashed up into pulses a few picoseconds long. Lensing due to air ionisation is a common problem with mode-locked q-switched YAG and YLF lasers if you focus the beam too tightly.
Likes mfb
I have recently joined this forum and have a question:If p3 and p4 represent the optical pumping power for a 3level and 4 level laser respectively, then what is the relation between them?
Related to Lasers can be used to ionize air....
What is the process of ionization using lasers?
Ionization is the process of converting a neutral atom or molecule into an ion by adding or removing electrons. When a laser is used to ionize air, it strips electrons from air molecules, resulting in a plasma of positively charged ions and free electrons.
What types of lasers can be used for ionization of air?
Various types of lasers can be used for ionization, including pulsed lasers, continuous-wave lasers, and ultrashort pulse lasers. The choice of laser depends on the specific application and the desired level of ionization.
What are the applications of using lasers to ionize air?
The use of lasers to ionize air has a wide range of applications, including in atmospheric sensing, air pollution control, laser ablation, and laser-induced breakdown spectroscopy. It can also be used for particle acceleration and plasma physics research.
Is ionization using lasers safe for humans?
Yes, ionization using lasers is safe for humans when proper precautions are taken. The level of ionization can be controlled by adjusting the laser parameters, and the ionized air quickly dissipates, making it safe for human exposure.
What are the potential hazards of ionization using lasers?
The main potential hazard of ionization using lasers is the generation of high-energy plasma, which can cause burns or damage to sensitive equipment. Additionally, ionized air can also produce ozone, which can be harmful if inhaled in large quantities.
  • Atomic and Condensed Matter
  • General Engineering
