Lasing experiment and the measurement of intensity
In summary, the experimenter found that current is not proportional to intensity, but proportional to the square root of intensity. They are still trying to figure out what they may have missed.
AlexCdeP
39
I have just completed an experiment on principles of lasing, constructing a laser and measuring the beams intensity distribution. This distribution of the beam was measured using a detector mounted on a traveling microscope. The detector had a pinhole cover such that only a small fraction of the beam entered the detector at once, and from this I could measure the current from the detector on an ammeter against the horizontal displacement. Now I must be going crazy because I spoke to a demonstrator in the lab and she said I can just plot this current because current and intensity are proportional. Indeed I proceeded to plot the data and the measurements fitted the predicted values. However I checked and current is not proportional to intensity, it is proportional to the square root of the intensity which mucks everything up. Can anyone think what I have missed.
P=I[itex]^{2}[/itex]R
and I=[itex]\frac{P}{A}[/itex]
so I[itex]^{2}[/itex][itex]\propto[/itex]Intensity
The plot comes out as a Gaussian distribution so I=I[itex]_{0}[/itex]e[itex]^{\frac{x}{w_{0}}}[/itex]
w is the beam width, I is intensity and, x is the horizontal position.
So if the current were proportional to the square root of intensity we wouldn't get this distribution.
Thanks in advance to anyone that can help.
The current through the dectector is generated by the absorbed photons. That is most likely why it is directly proportional to its intensity.
The key is to better model the detector.
Your equation of P = I2R is correct, but don't forget that in a typical photo-detector, the resistance R of the photo-detector is not constant, and changes with the light's intensity. The fact that R is not constant is typical of most photo-detectors. Many photo-detectors work at a constant voltage (roughly speaking) rather than have a constant resistance.
Let's step back a moment and consider an ideal photo-detector. For example, let's consider an ideal solar cell that converts light power to electrical power with a constant efficiency. Also, let's assume that the potential difference (aka. voltage) between the terminals of this ideal solar cell is constant. (In practical solar cells this constant voltage [Edit: I should probably reword that as constant "emf"] idea is a fairly good approximation of their behavior.) Now what is the relationship between the light intensity and the current, given that?
Everything I've said in this post depends upon the characteristics of the detector though. If you do some investigation and find out that the detector's voltage doesn't change much over varying light intensity*, then I think you've found your answer.
*(At least in the range of intensities that you were measuring in the experiment.)
Likes 1 person
Thanks so much for your replies! Collinsmark, I think you are most probably right. I will do some further investigation into the detector and I'll probably find that the voltage doesn't change significantly. If the the resistance of the detector were to decrease at the same rate as the intensity were to increase(not by the square), this would cancel the effect of the square term on the current I think(not including some constant term)? Thus leaving P proportional to I, which is what I need for my equation to work, so this is what I expect to see when I check tomorrow. Thanks again, I'll look into it and point out any error in my thinking here if you see it :)
AlexCdeP said:
I
You mix two different things, both denoted by I, and also two different powers, denoted by P.
In P=I2R, I is the electric current flowing through a resistor R, and P is the power dissipated in the resistor.
The intensity of light is also denoted by I, and it is the power of the laser light (P) falling onto an area A , divided by the area. The light intensity is proportional to the number of photons, perpendicularly crossing an unit area in unit time.
The photodetector usually works on the principle of photoelectric effect, and measures the photocurrent, the number of electrons released by the light from the photocathode in unit time.
The number of electrons released is roughly proportional to the number of incident photons.
ehild
Likes 1 person
Related to Lasing experiment and the measurement of intensity
1. What is a lasing experiment?
A lasing experiment is a scientific experiment that involves studying the properties of a laser beam. This typically involves manipulating the laser beam and observing its behavior and characteristics.
2. What is the purpose of a lasing experiment?
The purpose of a lasing experiment is to gain a better understanding of the properties and behavior of laser beams. This information can then be used for various applications, such as in medical treatments, communications, and manufacturing processes.
3. How is the intensity of a laser beam measured?
The intensity of a laser beam is typically measured using a device called a power meter. This device measures the amount of power per unit area of the laser beam, and this measurement is known as the intensity.
4. What factors can affect the intensity of a laser beam?
There are several factors that can affect the intensity of a laser beam, including the power source of the laser, the distance the beam travels, and any obstructions or reflections in its path. Additionally, the type of material the laser is passing through can also impact its intensity.
5. How can the intensity of a laser beam be adjusted in a lasing experiment?
The intensity of a laser beam can be adjusted in a lasing experiment by changing the power source, altering the distance the beam travels, or using different materials or filters to manipulate the beam. Additionally, the beam can be focused or collimated to increase or decrease its intensity.
  • Quantum Interpretations and Foundations
